Question about Maytag MDB7100AWB Dishwasher
No power to control panel after power surge
Hi, Our dishwasher worked fine until today. I tried to use it and there is no power to the control panel. I push Auto Clean, and nothing happens, no lights turn on when I press any of the push pad. We had a power outage yesterday, however this is not the first one that we've had. I checked the breaker and it is fine. Any idesa? Thanks Last week it wouldn't completely drain. Resolved that problem pushed the dishwasher back into its space and now I have power in all the wiring but nothing will light up on the door panel.
  • 8 more comments
  • yao1 Mar 03, 2008
    same issue. Any solutions out there?
  • Gary8 Mar 15, 2008
    I now have the same problem only there was no power surge. Power to outlet is good but the control panel is completely dead. Is there a fuse or internal breaker on this thing somewhere?
  • sacagc May 01, 2008
    Same problem. Any solutions yet? Our dishwasher worked last week but we did notice a leak by the door. Now when we try to turn it on nothing happens.
  • Anonymous May 06, 2008
    Same problem--electrical fuse is great--no power to dishwasher/control panel after storm and power surges.
  • lowriderbass Aug 25, 2008
    Same problem, lights dont work, power is good, took the front off where the light control is and no fuses? Any ideas?
  • Anonymous Oct 04, 2008
    Same problem here Mid-cycle it just quit. Power is ok. Any kind of re-set button somewhere or is the control panel just dead?
  • ukosfamily Nov 09, 2008
    Me too! I close the door and no lights come on when i push the buttons. Help!
  • kricket0x0 Dec 01, 2008
    Same here came home today and no power
  • wpeav May 11, 2010
    I have the same problem except for the drainage. I suspect that the timer has died, but don't know. I"d appreciate some help. Tks
  • ukosfamily May 11, 2010
    for some reason after taking panel off and poking around then putting back together again then waiting 20 minutes..it started working! I suspect there is moisture building up on the electronics somewhere behind the door panel. I have had some unusual behavior ever since the recall repair to the door panel...should never have let them "fix" it.
  • 734 Answers
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Dec 02, 2008
Dishwasher not working, no lights on control panel
If your good with electricity get a meter and with the unit unplugged check the resistance across the thermal switch... it should be 0.0 ohms(omega symbol) if a thermal switch is blown it will be open. and read unlimited ohms... I doubt if it is the thermal switch. Check first if you have voltage to the control board you should have lights on it. If no light then probably The door interlock switch has failed,, that is the first thing that I would suspect as I had that happen on one of my units... figure out how to bypass it or operate it.
Jan 18, 2014 | KitchenAid Dishwashers
No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
2. Door switch
3. Timer
4. Selector switch
Jul 13, 2009 | Maytag MDB7100AWB Dishwasher
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Diswasher stopped working
There is a thermal fuse on the controller that commonly goes out. If you take apart the panel, and see the computer part, there is usually a part clipped on the side with 2 wires on it. When that goes out, it acts like there is no power to the unit. Very easy and in-exspensive to replace if that's it. It's pretty common on those. Good luck
Feb 15, 2009 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Sep 30, 2007 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB Dishwasher Logo
649 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
