Your problem may be due to weak/worn out batteries or corrosion on the
battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, your
batteries may need to be replaced, or the camera may have
a problem that requires professional repair.
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-H2 Digital
when i try to take a pic the orange light comes on then gos off might take a pic might not what do i...
(More)
when i try to take a pic the orange light comes on then gos off might take a pic might not what do i change to make it wirk right
I only can turn on my camera if I start it directly into the Playback mode, if I either press the...
(More)
I only can turn on my camera if I start it directly into the Playback mode, if I either press the shutter, press the playback mode button again to change to capture mode or move the Mode Dial it turns off.
