Question about Mitsubishi WD-52628 52" Projection HDTV
WD-52628 Mitsubishi - change inputs
When helping a friend, we can;lt change th video input source. Slecting device menu seems to turn the set off.. How can we cahnge the video source. No manual and unable to find an input or source button or either the remote or front of the tv.... Thanks!
  • Anonymous Mar 08, 2008
    The device menu button seems to turn the set of what do i do
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Posted on Mar 26, 2008
  • KHPainter Mar 26, 2008
    Me again. I found the instructions for getting to the service menu on line: 1. Press TV Menu and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV. 2. Select Reset System defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults). Hope this works for you.
"TV RESET"Press "TV Menu"Slowly press buttons 1, then 2, then 3."RESET SERVICE MENU" screen will appear.Follow onscreen instructions. TV will be completely reset to factory defaults.
Posted on Sep 28, 2011
Mitsubishi wt-42311 wen t off when I switched station and wont come back on. green lite on t v goes on for a split second and shuts off. T V is 5 yrs old,just passed warrenty.
Posted on Dec 05, 2008
Mitsubishi WD-60C9 changing inputs on its own whats the cause of that?
HDMI auto is ON. Go to menu settings and turn OFF auto HDMI. That will stop the auto switching. Regards.
Aug 18, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Msi tv out
If the TV has a VGA port, then you can connect the U100 directly to the TV. Otherwise, you will need a converter depending on the inputs of the TV.
In the case of a VGA port on the TV, turn off the TV and the netbook before connecting the two devices. Then turn on the TV and set it to the VGA input. Then turn on the computer. The monitor should be recognized when the OS boots up. You can press <Fn>+<F2> to force the communication. In the Display properties (right click on the desktop), you should be able to change the display mode.
For composite video, the converter option uses devices like these: . Again turn off all devices before connecting them and turn on the computer last. If a TV has only an RF (antenna) input, you can connect the VGA to composite converter to an RF modulator. However, signal losses may degrade the video.
I hope this helps.
Jun 20, 2012 | Computers & Internet
I have a Mitsubishi 52628 that has a strange pattern on the left side of the screen.
I had this strange occurance too. It appeared right after I connected the antenna wire so I changed to another style input and got the full screen shot. i did not investagate the input on the tv further as I had other connections i was able to use. I hope that helps with yours.
Jan 31, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Which button on the remote control is for switching from TV to AV (VCR)?
The TV/Video button on the original remote for the KDL-26S2000 should let you cycle through the inputs on the TV. This button is at the upper left of the remote. (However, if you have set the system to Skip inputs, you may need to remove the skip option.)
There is also a TV/Video button on the front of the TV. It's the second button from the left on the panel (it's just to the right of the menu button).
To reset the input list, press Menu and navigate to Settings. Select the Setup sub-menu and then select the Label Video Inputs. Give the input any label other than skip.
Some TVs work best if the TV is turned on and set to that input source before you turn on the source device.
For additional information and pictures of the menus, see the manual. It is available from Sony support: (see the Manuals, Specs and Warranty tab). The direct link to the manual is .
I hope this helps.
Dec 31, 2011 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Snowy picture, device menu will not come up.
Depending on what devise, (cable box, game system, movie players) the sign of snow is no signal, there are inputs that you hook a devise up to on a TV, you have to change the input on the TV to pick up the signal of the unit, on the remote or TV itself, there with be a(n) "input", "source", "tv/video", or "video source" button that you can choose the same input you chose in the back of the TV.
Jun 28, 2011 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
764 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
