Find the smart/learn button on the rear of your motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you want and press enter.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sears Craftsman LiftMaster
Sears Craftsman LiftMaster Chamberlain Garage Door Opener...
the garage door stated to open and opened about two feet and then stopped. when the open button was...
(More)
the garage door stated to open and opened about two feet and then stopped. when the open button was hit again the motor went and sounded like it normally did but the door never moved I hit the button a few times and it kept sounding like it was working but without the door moving, what could be wrong?
The door seems to be stuck down...like the upper limit has been moved to 3 inches above the floor....
(More)
The door seems to be stuck down...like the upper limit has been moved to 3 inches above the floor. When the unit is activated it first tries to go down (the door is down already) and the carriage runs into the t-bar bracket that attaches to the wall. I think the carriage needs to be moved to the open position (the system thinks the door is open). How do I manually adjust the chain?
Craftsman GDO don't not respond other than a click noise when remote or wall unit is pressed. When...
(More)
Craftsman GDO don't not respond other than a click noise when remote or wall unit is pressed. When power is removed, then restored, wall switch is pressed, unit clicks, then green LED on back of unit flashes 5 times, blanks for a few seconds, then repeats 5 flashes...... Any ideas for reset?
i have 2 craftsman garage door openers one is made in 10/01 and the other is made in 02 will the...
(More)
i have 2 craftsman garage door openers one is made in 10/01 and the other is made in 02 will the older remote work fo the newer remote
My craftsman door opener went up half way and stopped. Light on u nit was not on and indicator light...
(More)
My craftsman door opener went up half way and stopped. Light on u nit was not on and indicator light flashed 5 times, the repeats 5 flashes. billybob
