Question about Nintendo Wii Console
Connecting to internet
I cant connect wii to internet i have a wired conection ihave bought lan adaptor and ethenernet cable using straight to modem im using windows xp error code 50100
  • 3 more comments
  • Philip46 Jan 06, 2008
    I am having trouble trying to connect nintendo Wii console to the internet thruogh a wired Linksys BEFDSR41W router
  • cdevito33 Sep 06, 2008
    have been trying for three days to connect via LAN and my modem. still not getting a connection.
  • Sharona Louviere
    Sharona Louviere Dec 13, 2008
    error code 52200
  • Anonymous Jan 02, 2009
    1. same
    2. same
    3. same
  • Anonymous May 11, 2010
    When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide
    and check out the guide available there, This DIY guide will show step
    by step pictures to fix the problems yourself without any technical
    knowledge...
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 38 Answers
One option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right after started to fall in place perfectly, just try what password type will work for you...my wii started connecting to my router and never had the same error code ever since.
Posted on Mar 08, 2008
    President:
  • 4,402 Answers
Http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
How do i connect my wii to the internet
there is two ways to get the wii connected to internet
You will need the Wii LAN adapter or a Wireless Router already in function
then on Wii options Wii Seettings go to Internet Conection Settings select Connection 1 (or any not used)
Select Wired or Wireless connection and follow the steps for the connection
For a detailed instructions see the followin linkg http://us.wii.com/connect/
Mar 28, 2011 | 2wire (1000-000057-000) Modem
Connecting internet
The Wii has built in WiFi so if you have a wireless modem all you will need to do is go to the Wii settings menu and select Internet, Next choose Connection Settings then select Connection 1. Here you will have the option to choose a Wireless conection -OR- Wired connection. If you have a wireless modem or Router click Wireless connection and choose Search for an access point then
select your access point from the list. Save then start a connection test.
If you do not have a wireless modem or router you must buy the LAN Adapter which you will find here http://www.amazon.com/Wii-LAN-Adapter-Nintendo/dp/B0014KM2KG. You will need that to connect a ethernet cord from your modem to the Wii. You would choose Wired connection and click ok to start the test. Good luck and have fun (",)
Jan 04, 2011 | Nintendo Wii Console
I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
    Connecting directly to a modem:
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
Sep 13, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
Wii wired internet connection problems
if you have all of these
Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
  • A Wii LAN Adapter (where to buy)
  • An active broadband internet connection, such as DSL or Cable.
  • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
  • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
  • An ethernet cable.
then go here for more information
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
this information was found on nintendo's customer service website
I hope you find it useful
Dec 29, 2008 | Nintendo Wii Console
Conection to the internet through land line
Land line? oh i see... wired connection. It looks like there is a problem connecting with the LAN adaptor.
The Error code has to do with some problem connecting via wired connection.
Try pluging it off and on again while the system is off
Try connecting it with a different LAN cable
Try fine tune some settings on the Wii system options
Try connecting with an other LAN adaptor.
Make sure that the LAN adaptor you are using is made from Nintendo.
If still not working just call the local Nintendo Customer Service and report the problem.
Jun 25, 2008 | Nintendo Wii Console
Remove the router, connect the phone wire to the modem and the lan to the system, now configure the modem as per the ISP details. This should solve the Problem. the modem itself acts as a router, when you have two routers your default gateway in the lan prorepties should be configured with the ip address of the router which is attached to the phone line. More over the ip add of the routers might be the same as the default is 192.168.1.1.
Because of this you might be getting the error message.
Jan 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
