Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Left Knob Settings
Hi all. Just moved to a house with the Viking 040 or 141 (not sure which). There is no documentation and the letters on the knob settings (mainly the left one) are worn. Could anyone enlighten me as to what these settings are?
A photo or perhaps even manual? THANKS!
  • ben_nyc Jan 07, 2008
    Thanks, but those websites don't seem to exist? Unless there are typos, I can't find them anywhere.
  • 640 Answers
Goto and search your model.they may have a manual.try also.
Posted on Jan 06, 2008
  • anthony james
    anthony james Jan 08, 2008
936 Huskylock needle bar does not move up and down.
First, make sure the machine is engaged to sew. some machines,
have a knob inside the flywheel on the left side that disconnect the sewing mechanism to wind a bobbin without the needle bar moving.
Embroidery Services
San Diego, CA
Jun 15, 2016 | Sewing Machines
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more :
    Mar 31, 2015 | Timex Indiglo Watches
    Clock settings
    For the mp235... the manual wasn't accurate. See below...
    To set the clock, push the source button until you're in standby mode. Hold the left knob down (volume ctrl) until menu comes up. Either push the left knob OR move the right up or down (can't remember which) until you see Clk Adj. Push the vol ctrl knob (I think). Then, the knob on the right goes left right for minutes/hours, and up/down for the other. I believe you can push the vol knob then once its set.
    Jun 20, 2010 | Kenwood KDC-MP205 CD Player
    Viking Husqvarna Model 6020 stitch selector will not turn.
    look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
    Apr 23, 2010 | Husqvarna Viking 1
    Bobbin does not wind all the way up
    I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
    Feb 08, 2009 | Husqvarna Lily 540 and 550
    Need New Fan knob for Viking VWH3048
    You could contat any viking dealer and they would be able to help you, or you could go online to; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
    Jan 31, 2009 | Viking VWH3048 Kitchen Hood
    Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
    Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
    Left Knob Settings
    On our model VUD141, the knob has a mark and the cycles are printed on the front panel. It is labeled as follows (starting from straight up and going clockwise):
    OFF - Heated Dry - No Heat Dry Sani Cycles 165 deg F - Power Heat Selection - No Heat Dry - Heated Dry
    Jan 05, 2008 | Viking 24 in. Professional Series VUD141...
    Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
    111 people viewed this question
    Top Viking Dishwashers Experts
    Starnley Johnwells
    Starnley Johnwells
    Lloyd Carter
    Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
