Question about Hitachi 43FDX15B 43" Rear Projection Television
43 INCH HIT ULTRAVISION
SMALL LINEAR RED LINE IN UPPER 1/3 SCREAN FROM RT TO LEFT, AND GHOSTING OF TEXT. WHEN LOOKING AT THE TEXT IN THE MENU IT IS PERFECT. ANY HELPFUL INFO? THANK YOU VERY MUCH
  • drewgenera Apr 03, 2008
    green shadows and double picture
Stks are bad red one should fix
Posted on Jun 13, 2008
How do you switch the am/fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen with no remote?
touch source button in the upper left corner until the tuner options are on, or until you see the stations,m then hit seek or tune to get the station you wish to play.
Nov 21, 2014 | Jensen Car Audio & Video
Convergence
did u do a repair in recent days
by replacing the convergence ICs?
Jun 18, 2008 | Toshiba 43A10 43" Rear Projection...
How do you switch the am and fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen
touch the source button in the upper left hand corner until you see radio, then hit tune or seek to get the stations you wish.
Nov 21, 2014 | Car Audio & Video
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Color convergence on our Phillips 46999302/17F
If you are not able to adjust the convergence using the remote you need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Example: RED moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Line in pic
Good Day, varndog;
Line on left side of pix,? It sounds like you have a high voltage leak. Check all high voltage cables and make sure that they seated firmly, all of those big red cables.
Good Day and Luck, big IRISH.
Apr 24, 2008 | Hitachi 43FWX20B 43" Rear Projection...
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Wavy lines / red ghosting
Sounds like your convergence amps need to be replaced (STKs). I am not sure what the rates are in your area, but typically you're looking at around $200 or so.
Jun 07, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
