Coleman Propane Forced Air Heater w/Electronic Ignition
Problem for Coleman Propane Forced Air Heater w/Electronic Ignition...
Colman mobile home gas furnace to use in my garage/shop
By tony_miklos on Nov 06, 2009
Colman Direct Vent air furnace (sealed combustion) Model# 7970-656/d Two questions. First, since this is a sealed combustion furnace, can I use it to heat a garage? Forget ''code'', there is no building code here. The insurance company just called and said it's OK to use in the garage does that sound right? I question this becasue the guy said "sealed combustion" has nothing to do with it being in a garage. Everyone else told me they use only sealed combustion in a garage where there may be fumes from gasoline, stain, paint, or other solvents.
Second, what are the specs. for the exhaust and air intake vent/flue? It's the exhaust flue inside the air intake pipe. More specifically, does it have to go straight up a certain height before going to a 90 angle and outside. How far can I make the flue pipe run? Also once outside how high does it have to go or can I use one of those... things that just stick out the wall, or is that only for a condensing furnace? If I go out low on the gable end, do I still have to go out above the roof even if the gable overhang is 10 feet up? Sorry for so many questions.
Best Solution
posted on Nov 07, 2009
Very Helpful)
acfxr
Rank: Guru
Rating: 90%, 64 votes
generally speaking a sealed combustion system is inherently more safe than a system that draws it's combustion air from it's ambient location. however, it cannot be considered 100% safe in a potentially hazardous location. The actual system that would be used in a "code compliant" installation would be a 100% outside air unit.
That being said, you can install this in a garage, the vent that you are referring to (if it is a standard mobile home system) is generally directly above the unit and usually no longer than about five feet. It also requires a listed and labeled termination "cap" If you install 90 degree angles or extend the vent too far you will have issues with condensation in the piping that will cause the pipe/ heat exchanger to fail prematurely.
If the system is a 90+ efficeint unit then the PVC venting is generally allowed to be about 30 feet long, with a 1/4 inch per foot pitch back to the unit for condensation, also the general mfg. instructions allow either 2- 90 degree or 4 45 degree fittings in the line. hope this helps
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thank You " - tony_miklos
Popular Solutions for Coleman Propane Forced Air
Questions and Unsolved Problems for Coleman Propane Forced Air
Do you recommend Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)?
Answer
Answer
My Coleman furnaces with electronic ignition just stopped working I think its the ignition. how do I... (More)
Answer
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution... (More)
Answer
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble... (More)
Answer
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then... (More)
Answer
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Propane Forced Air...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
