My Toshiba Satellite A105 screen comes on for a little bit, flickers and then shuts off. However I can faintly see the screen, and the laptop works fine when hooked up to the external monitor. Wondering what the problem is ? Is it the inverter, backlight or the whole screen ?
Thanks,
Jack
Comments:
Nov 09, 2009
- Thanks for the info. So how do you suggest I proceed ? Should I start with the backlight first, then the inverter and if nothing works then the CFL. WOndering how much a CFL will cost. I'm seeing a wide range for A105 CFLs ranging from $70 to $200. What is more accurate.
Thanks, Jack
Nov 09, 2009
Thanks, Jack
If you can still view screen if you view it in an angle or spot a flashlight on screen. Then, definitely it is a problem on backlighting, might be loose connection, inverter giving up or cfl giving up.
I've had my Satellite A215 for a little over two years and I've never really had any problems until...
(More)
I've had my Satellite A215 for a little over two years and I've never really had any problems until now.For the past couple of days my laptop will be plugged in, but it will suddenly stop charging and the battery light will start blinking orange and the power light will turn a wierd blueish orange color. If I mess with power cord for about half an hour (unplugging it from the laptop, then the outlet, then disconnecting the cord from the power brick, etc.) it will eventually start to charge again and the lights will go back to normal. Do I need a new battery or a power cord, or both?
i have toshiba satillite a105 laptop, just now i tried upgrade the ram. after that the diplay...
(More)
i have toshiba satillite a105 laptop, just now i tried upgrade the ram. after that the diplay disappear. now the power led is blinking slowly.
i have toshiba a100 .. its not turning on.. when i put the charger on and power on botton its flash...
(More)
i have toshiba a100 .. its not turning on.. when i put the charger on and power on botton its flash bettery light 5 times .. but not turning on .... plz help me to solve this prob...
Laptop was on and all of a sudden it stated that it was going into hybernation and since then it...
(More)
Laptop was on and all of a sudden it stated that it was going into hybernation and since then it won't turn on at all. I do notice a yellow light blinking in the battery indicator when I press the button to turn it on.
