Question about Motorola Mobility H700 Wireless Headset
H700 Loosing Charge Quickly
I seem to be loosing charge, I think. I loose connection to my phone on and off at close intervals. I recharged the earpiece then worked fine. Reoccurs after only wearing earpiece for a few hours. Is this common?
    Genius:
  • 1,003 Answers
I think the normal talk time is around 6 to 8 hrs if your battery is holding less you probably have a unit with a faulty battery
how old is your headset
Posted on Jan 14, 2008
My 2010 Mitsubishi gallant feels like its loosing power I think its the alternator can I charge the alternator
the alternator is only there to charge the battery. You can't charge an alternator! :>) Or did you mean to write 'change'?
Loosing power could be a few things. Bad gas, water in gas, dirty, badly gapped or old spark plugs.
Aug 15, 2015 | Mitsubishi Cars & Trucks
Tip
Switch playing up
I have a H700 , I bought last year and hardly used. I tried to use it few days ago and it keeps loosing connection to my phone. I figured out that the headset switch is very flaky and slight touch makes it connect and disconnect the bluetooth connection to my phone. Any clue to fix it ??
on Jun 19, 2008 | Motorola Mobility H700 Wireless Headset
Battery keeps loosing power
this happen regularly from a weak battery cell, and somtime from components on the circuit board. all u need is to change the battery or it cell, and for the circuit board u need to do brush the board with tinny and heat it up with vacuum use for phone.
Apr 17, 2012 | Samsung Infuse 4G Smartphone
FREON COMES OUT OF LOW SIDE PORT WHEN I TAKE CAP OFF
This means the shreader stem valve (like in the tire stem) needs to be tightened or replace if tightening doesn't do the trick. There is a specialty tool we use to remove the stem and replace it without loosing the charge. The stem itself is very cheap. This is something that spending a little with a repair shop could save big on the damage to the system if this issue isn't solved quickly. If you know an a/c tech he most likely has this tool, perehaps an autoparts store would. If you loose all the charge, a vacume would need to be pulled on the system before you can recharge the system. Please remember to rate our ansewers to improve our service.
Jul 18, 2010 | 1996 Ford Explorer
Norelco shaver doesn't recharge.
If the shaver won't hold a charge it usually means that the batteries need replacement. This requires disassembly and soldering skills. It's not hard to do but if you're not handy with a soldering iron a shaver repair shop can do the work for you. However, if you have to pay to have it done and if the blades are more than two years old and need replacement, you might be better off just buying a new shaver.
Jul 05, 2010 | Norelco Cool Skin 7775X Electric Shaver
O2 orbit losing charge very quickly
my xda orbit is loosing charge quickly too, if i find a soloution ill wb.
im going to try a thorough clean of the motherboard, scratch connections etc and a hard reset.
looking like a new battery may be in order though..
think there £5 on ebay..
Dec 26, 2009 | O2 Xda Orbit Smartphone
Battery is loosing charge very quickly thru very little use after it was charged over night model ns-dv2g
how old . .
is it a built in battery ?
after each use - little as may be, do you recharge ? - if so, this can cause problems.
Most occasions you are best to run devices down to no power then recharge - this will maximize the batteries life expetancy.
Aug 16, 2008 | Insignia Audio Players & Recorders
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
103 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
