dont clean, unless glued up, but they dont like it, can spot remove stuff with metho, but they last about 60000 pages cause little problems unless torn, Some models just unclick by buttons either side near hinge others are fixed and normally thrown if damaged or charged heaps.... Most faults are alignment issue, faulty remanufacture cartridges or damaged fuser (hot bit) roller causing creasing..
if really required than can try blower for cleaning the transfer roller generally its not recommended to touch the roller as Minor oil or dust can cause print quality issue
When I print a page with color across the entire width of the page, the colors on the left hand side...
(More)
When I print a page with color across the entire width of the page, the colors on the left hand side are lighter than than the same colors on the right side. The toner cartridge is new.
My 2600N HP color laserjet, The colors are not lined up, Printer needs to be manually calibrated....
(More)
My 2600N HP color laserjet, The colors are not lined up, Printer needs to be manually calibrated. Seams like red is not aligned it is printing higher than it is supposed to.
have a hp 2600n when I print e two rows of pictures lanscape the bottom row is way too dark but the...
(More)
have a hp 2600n when I print e two rows of pictures lanscape the bottom row is way too dark but the top row is just fine. How do I fix this
