Timex Ironman Triathlon 30 Lap Shock Watch T5J391 Logo
Posted on Nov 06, 2009
How do I get my indiglo timex watch off military time?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 06, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25151
Points
14
If it is the five button type I have (there are several) you hold "SET" until a field starts flashing. Then hit "MODE" until you see "24-HR" in the display. Hit "LAP/RESET" once and it should display "12-HR". Hit set again and you are done. Also note that timex has all manuals available online for free,searchable by the "module number" you can find on the back plate of your watch. Hope this helps.
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
1helpful
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
6helpful
I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
How do i change my timex from military time
The owner's manual that was sold with it should guide you. If it's missing, get a good hand-lens. Take the watch under a good source of light, and aim the hand-lens to the edges of the watch. You should see 12/24hr button. Press the button once. The time should change from military. If it doesn't , press and hold the shortest button for about 5-seconds. Then press the button that is marked 12/24HR.
2helpful
3answers
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
23helpful
3answers
INDIGLO watch setting procedure
how to set the time from military to reg
10helpful
2answers
Timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
26helpful
5answers
Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
