Agitator will not spin
Hi
The agitator isn't spinning and the bolt is not stripped. However, the bolt will not completely tighten How can I fix this problem?
Thank you.
Leeann
  • 1 more comment
  • Leeann108 Jan 05, 2008
    Whirlpool LA5100XTW0
  • Leeann108 Jan 06, 2008
    No it barely moves when full of water. If i put pressure on the cap of the agitator then it will move a little stronger. I found the bolt was completely out one time and put it back in and tried to tighten it but it would not tighten completely.
    Thank you
    It also makes a clicking sound when trying to agitate
  • 90 Answers
What brand of washer are we talking about?
Posted on Jan 05, 2008
  • Douglas Woods Jan 05, 2008
    When full of water does the washer agitate?
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
Agitator spins freely as if not connected
Check to see of bolt is tight that holds agitator in place
Oct 02, 2009 | General Electric WHDSR209DWW Top Load...
Kenmore washer (27yrs old model821728 just spins does not agitate
hi, the clutch and agitator mechanism is damaged. you will need to replace the clutch and, i would advise to purchase a complete agitator kit. this will allow you to rebuild the stripped agitator components.
May 21, 2009 | Kenmore Washing Machines
Agitator not spinning hear sounds inside the shaft
Hi, this agitator may have stripped all of the internal gears and plastic drive adapters that allow it to preform its actions during the selected cycles. The only solution here will be to replace the agitator and drive shaft as well. you can order a complete agitator kit with all the parts as well. this will fix this issue. Please rate and god bless:)
Apr 13, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Agitator won't spin back and forth like its stripped
I think what you have going here is some worn agitating ears. In the appliance world we call them dog ears. You have to remove the fabric desp, it should just pop off. Under there will be a cap that you can grab with a needle nose pliers and pull the cap off. Now you will be looking at the bolt that holds the agitator to the shaft. Remove this bolt and you can get to the dog ears and plastic bearing. There is a kit for this and the part number is 3951682. This is not a hard fix...just take your time and observe. Catriver...post back.
Jul 29, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
