Question about Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer
Change chennel from 2 to 1
I see [2] and want to revert to [1]. How? Help!
0 characters
1 Points
Can not get phone time to stay for daily savings time change.
is the date set properly but after changing the time and date you need to save or it will revert to the previous setting
Mar 14, 2015 | Panasonic Phones
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
NORSTAR M7310, AUTO ATTENDANT...main message is fine, but then I had a message that stated for XXXXX press 1, for xxxxx press 2, for xxxxx press 3, etc... I have lost that message I recorded and it has...
Check the greeting table for the line to find what greeting it might be using 1, 2, etc. this might be where your strange message is located and the AA is using it instead of the CCR 1.
Sep 30, 2013 | NorStar M7310 Corded Phone
At&t cl82401 date and time
I have the same question for my AT&T CL83212 cordless phone. I set the time, but when a call comes in the time reverts to 3 hours back - Pacific Time. We are Eastern Time. I called AT&T &
was send a new Uverse modem (???) - that did nothing. I am ready to return the phone.
Apr 20, 2013 | AT&T ATT CL82401 DECT 6.0 Digital...
Phone time is reading 2 hrs. later than actual time; have reset,
Whoever is controlling the incoming calls is sending a different time zone. If it's the telco, call them. If it's a VoIP carrier like Vonage or Packet8, get them to let you log into the box and change the time zone offset.
Feb 25, 2009 | Panasonic KX-TG1033S Cordless Phone
How do you change the date on executone 64 phone? Our power went off & it reverted to Jan 1. I was able to change the time, no problem, but can't figure out how to change the date. Thanks!
Step 1: Press Menu key
Step 2: Press Park 3 key
Step 3: Enter password followed by # key ex. 543#
Step 4: Enter 9819
Step 5: Enter date with # in between. Ex. 01#26#2009#
Hopefully this will solve your problem.
Jan 26, 2009 | Executone 64 Corded Phone
Answering machine is in spanish not english
According to the manual, you hold the SKIP button down for 2 seconds and it reverts back to English. (Don't hold it down again or it's Espanol time).
Jan 20, 2009 | Uniden Cordless Phone
Visys time/date display settings will not stay correct - help please!
I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
Jul 07, 2008 | RCA 25404RE3 Corded Phone
I cannot change the language setting
To return the base announce language to english press and hold the skip button for two seconds. To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done. Hope this helps!
Apr 21, 2007 | GE 27995GE2 Cordless Phone
Changing the answering machine
Press and hold the skip button for 2 seconds, will revert back to English
Feb 02, 2007 | GE 5.8 GHZ Answering System w/ Caller ID
Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer Logo
21 people viewed this question
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
