Question about Fujitsu 12C1 Air Conditioner
Need Fan Motor Part Number for Fujitsu 12C1
AC unit has been tripping the circuit breaker at times over the summer. Taking a look at it, the fan motor appears to be almost shot. I need the part number and a suggestion on where to look for one of these.
  • 288 Answers
First, is it in warranty? If so, call the installer. Fan motors don't usually cause the breaker to trip, and usually if they go bad, that's it. They don't work again. I would look at the compressor. Also change the air filter and clean the condenser and evaporator coils. BUT, if you want to replace the motor, read the I.D. label on it. You may need to remove it to do this, but it will have all the info you need. With this information, go to the local appliance parts store, and they can match it up with something that will work. Most of these motors pull no more than 8 amps, so for one to trip the breaker, which is at least 20 amps, I assume, the internal overload would turn it off before that happened. I would bet that when the breaker tripped, it was a hot day. Clean the outside coil, a hose will do fine. and change the air filter at least every 3 months, depending on hoiw much its used.
Posted on Jan 12, 2008
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
How to remove the evaporator fan from a Fujitsu 12C1
Unscrew pront panel and remove it. Unscrew PCB seating screws and remove it. Unplug motor jack, other jacks. Now unscrew motor seating screws, remove motor with blower. Keeping outside you can unscrew the blower wheel from the motor. Thanks.
Oct 18, 2011 | Fujitsu 12C1 Air Conditioner
The fan will not engage when unit is turned on and after 5 or so minutes the circuit breaker trips.
since the fan doesn't run - the compressor heats up and pulls excessive amps and trips the breaker.
99 out of 100 times your fan motor will be bad.
You need to replace the motor.
Jun 07, 2011 | Kenmore 74123 Air Conditioner
Breaker trips on unit. Fuse in house is ok. As soon as AC unit turns on it trips the breaker outside next to unit.
you have a 'direct short' - most likely the compressor or fan motor.
you could isolate it to one or the other by (be sure all power is off) disconnecting one of them and turning the unit back on.
For example if the fan motor is shorted and you disconnect it - the breaker will hold and not trip and the compressor will come on - which will tell you that you need to replace the fan motor.
If you do this and it still trips the breaker then reconnect the fan motor and disconnect the compressor and try that.
If the breaker holds and the fan motor runs then you know the compressor is shorted.
Note: the fan motor can be replaced with not a lot of trouble depending on how mechanically inclined you are - but the compressor will take a qualified serviceperson.
Jun 06, 2011 | Heating & Cooling
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
Outside unit tripped the breaker. flip the breaker
Check the fan relay or contacts first. If the compressor comes on then your fan may be locked and will need replacing.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
AC not working
Try opening the front of the machine and check the circuit board has not got anything on it the could cause a short. I had the same problem but mine was a gekko that fried on my circuit board.
Sep 25, 2008 | Fujitsu 12C1 Air Conditioner
Fujitsu Model #12C1
Unplugg it and sound like a dirty out-of-balance fan squirrell cage. When was the last time you changed the filters? Sorry-about-that, you saying, What filter?
Aug 31, 2008 | Fujitsu 12C1 Air Conditioner
Fujitsu 12C1 Air Conditioner Logo
191 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
