Admiral AW22 Top Load Washer
Problem for Admiral AW22 Top Load Washer
The washer will fill and agitate, but will not
By mjmcnamara on Nov 06, 2009
the washer will fill and agitate, but will not drain or spin. any ideas?
Solution #1
posted on Nov 06, 2009
Not Rated)
mandlapplian
Rank: Guru  Washers & Dryers  Expert
Rating: 94%, 27 votes
check and see if your machine has a drip dry switch if so set on the normal or off position if do not have this function check drain pump for blockage or kinked if all clear water pump may be faulty also could be timer problem but more likely water pump be sure to switch of power safety first let me know how you went
Was this helpful?
Yes
No
Popular Solutions for Admiral AW22 Top Load Washer
Questions and Unsolved Problems for Admiral AW22 Top Load Washer
Do you recommend Admiral AW22 Top Load Washer?
Answer
Answer
When my washer goes into spin cycle it makes really loud noise and spins really slowly?? Can u tell... (More)
Answer
machine vibrates and moves all over the floor
Answer
Admiral Capacity Plus washing machine agitator sounds as if it's stripped after daughter ran full... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Admiral AW22 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
