Question about Proview PL926WBi 19" LCD Monitor
LCD display Proview
I have a 19' Proview LCD display. Recently it startet turning off by itself after working for 4-5 sec.We connected it to another pc and the display acted the same way - it worked for 4-5 sec, then it turns off. We have to press the on/off buton to turn it on, works for 4-5 sec and then goes black again.
I have a proview PL926WBI lcd monitor when i turn it on the background is a little red tint to it wich lightens up after about a minute or so then the screen goes black. I manually turn it back on and does the same thing . over and over. I have tried different cables and switched computers it still does the same thing .
  • 10 more comments
  • zaggynl Jan 10, 2008
    Have the same problem, tried two differenc PC's as well.
  • Anonymous Mar 25, 2008
    I bought 2 of these one has this prob and the other works fine. I think it's a transistor problem, I got mine off e-bay and the fellow has closed his store now (suprise).
  • KKST Apr 07, 2008
    surprisingly same problem. I own it from the past 10 months.
    What's the solution, by they way?
    --KKST
  • Anonymous Apr 13, 2008
    monitor comes for a few seconds then goes off
  • tester23 Apr 15, 2008
    I am having the same problem and I have already replaced all the compactors on the power supply board. This had no effect.. Black screen in two or three seconds with the power staying lit.
  • Dumbace Apr 24, 2008
    Ditto
  • Anonymous May 11, 2008
    I have exactly the same problem...no need to re-write it. Monitor was made Feb 07 so I assume it is still under warranty but the store I bought it from (Wal Mart) says I must send it back to the manufacturer. Problem is...I cannot find info on Proview to send for repair or replace. Please Email me if you can help [email protected]
    Thanks, Chris
  • bmw2002m3 Jun 08, 2008
    same problem 10 mounths old ,man date feb 07
  • netaddict Jun 14, 2008
    Our Proview just started doing this same thing....its so annoying. We went and bought an LG....never going cheap again!
  • janeska7996 Jun 19, 2008
    I have the same problem as well. Days before it went off, the screen was kind of flickering Like it couldn't quite adjust the brightness.. After a few days, it just went blank! I would push the power button off, then on, and it would turn on for like 4-5 seconds, and then turn off. Now I can't get it to stay on!! Help!
  • Ranny Dale Chadwick Nov 16, 2008
    Same problem but the model is 700p, it is a 17" monitor
  • Anonymous Dec 03, 2008
    I have almost same problem I have (Polyview monitor V293 LCD )work good for 15 minutes or even 3 days suddely turned off completly even with no power light . than turned back on only when i displag power socet back of the off monitor .. and plaged it on again monitor came back to the normal for couple of hours and sometimes for a couple of days
    if you have a solusion please halp
    thank you
You need to contact Proview. It is a problem with the monitor. I had the same problem and I was lucky. The warranity was going to run out in 15 days. They sent me a return number "I had to pay shipping and insurance" and they sent me a replacement. The replacement had a problem with the screen. It looked like it had been shot by a bb gun. Proview is refusing to replace. Hope you have better luck. Here is their contact info.
By Phone:
Service Hotline: (800) 776-8439
Office Hours: 8AM to 6PM Pacific Time
Posted on Jun 01, 2008
I know this problem, the blacklight inverter burn out. I hav the same problem on my Dell monitor. After replace the blacklight inverter, it works perfectly.
Posted on Apr 20, 2008
I have the exact same problem after owning for 12 months.
Posted on Mar 19, 2008
Im having same issue :/ exactly even
I have a some problem
Posted on Jan 11, 2008
6ya staff
SOURCE:
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Proview fv-926afw 19'' LCD flickers and buzzes
If you have a capacitor tester.. i'll be much better at least you would know which caps that actually failing..
I would replace all the caps if you dont have the tester.. and while your at it. try to resolder connections and some parts like transistor etc.. maybe they have "cold solder"
May 04, 2009 | Panasonic Computers & Internet
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Colored lines on screen
This may be caused by the death of a display driver circuit and these might be integrated with the display itself.
The pixels on the screen are controlled by an X-Y matrix and the matrix may have signal lines that are somewhat shared for different screen positions.
I doubt that this is DIY project and the failure can only be located by an equipped and trained tech.
Feb 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview monitor problem
I bought Same Monitor Dec. '06 and Jus last week It faded to black and then now doesn't power on. my protection plan sent me a new one that powered on for like 20 secs. So now I have another one coming. I also knows its not my PC cuz I'm using a monitor right now. I think Proview and Circuit City Sucks
Jan 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor turns on then off.
Jan 11, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
533 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
