Question about Coby MPC-848 MP3 Player
Device error I cannot open or use this player. I get an I/O device error
  • 3 more comments
  • Tvell Jan 06, 2008
    I download music onto my player then I started to listen to it and it turn off. Before it turned off, it said error, now it will not turn back on.
  • Anonymous Jan 09, 2008
    every time i try and turn on my mp3 player it keeps turning its self off and then back on even when ii tryand plug it up to the computer it just keeps saying over and over again that a new hardwear system has been found but ive changed the batterys 3 times thinking that that was it ut its not please help
  • Anonymous Feb 17, 2008
    I/O error when trying to download
  • greenp Feb 18, 2008
    i get I/O problem when I try to copy music
  • Anonymous May 11, 2010
    how will i fix my mp3 player having i/o device error?
    Problem Solver:
  • 38 Answers
Try fommating it from the computer..it might work. if i dosent you should go back to the shop you bought it from and they might be able to do something about it..
Posted on Jan 12, 2008
6ya staff
SOURCE:
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
System files are missing
How to recover system files on H10?1.4_4_2012_7_54_27_am.jpg2. LCD on H10 displays "USB Connected" and then double click "My computer".
3. Click right mouse on "H10" drive and select "Properties"
4_4_2012_7_55_46_am.gif4. Go to Tools -> Error checking -> Check Now -> Check "Automatically fix file system errors" and click start.
4_4_2012_7_56_53_am.gif5. It will take you around 1~2 minutes, 5 minutes at maximum.
4_4_2012_7_57_35_am.gif6. Go to "Tools -> Folder Options -> View" on Windows Explorer. Uncheck "Hide protected operating system files(recommended)". Click OK to save properties.
4_4_2012_7_58_37_am.gif4_4_2012_7_59_08_am.gif7. Double click on "H10 drive" and delete "System" folder.
8. Open iriverplus and transfer music.
If your device was detecting by USB cable. Then update the firmware for this device:
1. Please open iriverplus3 and connect your device with USB cable.
2. After connecting your device, please follow the steps below to upgrade New Firmware
** Tools -> Portable Device -> Firmware Upgrade **
3. After upgrading the New Firmware, please check the firmware version before playing device.
** Setting -> Advanced -> System information **
Hope this will resolve the issue.
Regards
Nandu
Apr 04, 2012 | iRiver H10 MP3 Player
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
I can't run Philips SA60xx Device Manager
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
Mar 21, 2009 | Philips HDD1630 MP3 Player
I/O device error in flash player
Allow unit to run dead.recharge battery.turn on and push reset(smallpaper clip in reset hole).turn off and back on .should now work.if notformat and download new soft ware athttp://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Oct 20, 2008 | Creative Labs Zen Neeon MP3 Player
Request could not be performed because of an I/O device error
Search for a reset on the device--mine requires a paper clip to reset
Aug 27, 2008 | Audio Players & Recorders
I/O device error
Make sure you have media player 11
then format the player and try again
Jan 28, 2008 | SanDisk Sansa c140 MP3 Player
Transcend T sonic 610 showed format error when switched on
Plug the device into the computer open the device port that it's pluged into and delete everything that you downloaded onto it and then retry to download the supported format that the device supports.
Dec 21, 2007 | Transcend T.sonic 610 MP3 Player
Error Code 82040100
ERROR CODE 82040100 SOLUTION: here's what I did to solve this problem: -update walkman's firmware to latest version (3.0) -control panel > system > hardware > device manager uninstall the driver for the walkman (remove device) -now connect player can initialize the player again, but I installed Sonicstage CP 4 which is much better anyway.
Jan 17, 2007 | Sony NW-A1000 MP3 Player
Coby MPC-848 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
