Question about HP VP6121 Multimedia Projector
HP vp6162 projector spots on projected image
Just changed my bulb and noticed there are little spots or blurry tiny light orbs on the image (esp. noticeable in dark areas on screen) cleaned the lens and its still there. I've never noticed those little blurry spots before I installed the lens...
  • toddboat Jan 06, 2008
    After I inserted another bulb...I saw the same problem...It looks like its actually somewhere in the lens....I can focus the lens and the little "orbs" come into focus...I see now there are about a dozen of these little specs...maybe dust/dirt? I can move the zoom in and out..and the little orbs seem to move with it...that's what makes me think its somewhere in the lens. I cleaned the front part of the lens with a soft cloth....
    Thanks
  • Anonymous Mar 31, 2014
    Changed lamp, still have spots on screen... Is there any way to clean the mirrors? they look like bubbles. How do you disassemble the projector?
    Scholar:
  • 146 Answers
You may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Posted on Jan 05, 2008
  • martin hogg Jan 06, 2008
    you may have accidentally touched the bulb while changing it and minute traces of skin oil and/or moisture are on the actual bulb, with the machine cold, try very carefully to clean the bulb with a very small quantity of white spirit on a non-lint material. It sounds as if the tiny light orbs you describe are drops of moisture. If this fails, the fault is with the new bulb, and you will need to get a service replacement.
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Mar 22, 2008 | HP Digital Projector Vp6120 Multimedia...
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
I have a 52" LCD
Can you still see the spot when the TV is off? In any event, the screen may have something on it or the mirror that reflects the image from the projector where the bulb is. Make sure the projector bulbs are clean. Good luck, thanks for using FixYa.
Mar 03, 2011 | Zenith E44W46LCD 44" Rear Projection...
Projected image is blurry, mostly at the top of half. Weird. Tried another laptop. Although that one was slightly clearer, the top of the image was still blury.
Clean the lens on the front, turn on the projector and wait for it to heat up, then turn the plastic ring on the front to change your focus. computer image can't be made blurry because of software. Blurriness is always something to do with the lens.
Jun 10, 2010 | Sanyo PLC XU35 Multimedia Projector
There is a large dark spot in the lower center portion of the projection area, I have cleaned the external lense and changed the bulb but the dark image remains.
if the spot is circular, check the lamp itself. if it has a flatter edge, chances are your light tunnel has collapsed and needs replaceing. it's not that old, so dell might repair it. but they might replace the entire optical engine, as they may not sell individual parts.
Dec 02, 2009 | Dell 2200MP Multimedia Projector
LCD projector spots showing up on the screen
there are light filters behind each lcd panel that determine the color of light going through it. because of excessive heat and dust, the filter tends to burn and cause discoloration in the image. if the image is bluish (cyan), the red filter is burning. if it's yellow, the blue is burning. if it's purplish (magenta), the green is burning. the filters will need to be replaced. unfortunately, many companies don't sell individual parts of the optical engine, so the entire engine might need to be replaced.
Aug 20, 2009 | Epson EMP S1 Multimedia Projector
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
HP VP6121 Multimedia Projector Logo
1,178 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
