Question about SanDisk Sansa e260 MP3 Player
My sandisk is not being recognize by computer
When I connect the sandisk ,the sandisk just makes a beeping sound but no display on computer that it is connected.
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
6ya staff
SOURCE:
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
My sanddisk won't connect to my computer what do i do?
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Jun 26, 2010 | SanDisk Sansa e250 MP3 Player
Computer will not recognize the Sandisk
Look for the driver updates for Windows. Checking your memory card on other PC is also recommended.
Dec 30, 2009 | SanDisk 2GB microSD Memory Card
When I try to type it makes a beep sound for every stroke and nothing is displayed?
You must be running a program that accepts text as input such a 'Word' or an E-mail program. The 'beep' means that each input (text) is not recognized by Windows.
Nov 12, 2009 | HP w1907 LCD Monitor
Operating System does not recognize San 230
What is your operating system? You may need to update your usb drivers.
Aug 28, 2009 | SanDisk Sansa m230 MP3 Player
My computer will not recognize my Sansa sandisk MP3 player. I tried to reset it, and when I get the "Please connect USB" message, it still won't recognize it.
Aug 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My computer wont recognize my sansa e260
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Then connect to your computer and see if it works
Hope it does..........Please rate
May 20, 2009 | SanDisk Sansa e260 MP3 Player
Does not recognize
The dinging sound is the USB port telling Windows that a device is connected, and does not necessarily mean that Windows recognizes a device.
Are you using Windows Media Player 10 or higher?
May 21, 2008 | SanDisk Sansa e250 MP3 Player
Freezing / no recognition by computer
It sounds like your computer is trying to read your removeable storage...rename them and that should solve your problems..make sure you dont have any printer anything connected when you are renaming them
Jan 01, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
