LOGIN
There is a login key for the router that can be accessed by opening the
address
http://192.168.0.1 as described: after the login all settings inside the router can be changed.
Note:
use a wired connection when going into the routers' ip address.
When you can not login with the default password, reset the device:
Restoring the Default Configuration and Password
This section explains how to restore the factory default configuration settings, changing the
router’s administration password to
password and the IP address to 192.168.0.1. You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the Web Configuration Manager.
• Press the WPS button and Wireless button on the side of the router simultaneously. You can
use this method for cases when the administration password or IP address is not known.
Resetting to Factory Default Settings
You can use this method for cases when the administration password or IP address is not known.
To restore the factory default configuration settings:
1. Press and hold the WPS button and the Wireless button on the side of the router until the Test
LED turns on (about 10 seconds).
2. Release the buttons and wait for the router to reboot.
WIRELESS SECURITY + PASSPHRASE
The wireless security is a network name for wireless connection called
SSID: the identification name of your router.
The passphrase is used for a
secure password getting permission to have
wireless data transfer from the router to the computer and vice versa. ( No internet connection so far: only Local Area Network [
LAN] )
MODEM
Because the device is a router / ADSL modem you'r able to setup the
modem part for connection on a telephone line to the internet / Wide Area Network [
WAN] .
You should use
passwords from the Internet Service Provider [ ISP ] enter and save them in the modem section of the device.
Support for DG834G on the internet:
http://www.netgear.com/Products/RoutersandGateways/WirelessGRouters/DG834G.aspx
http://www.cnet.com.tw/product/cwr-854.h... Did you change them from the factory standard ones they come with?
