Question about Yamata PSP-990A Iron
Won't heat up
Light comes on, (indicating unit is working) but it won't heat up. this is a yamata steam press
  • 2 more comments
  • Anonymous Jan 19, 2008
    I do that and still don´t work, all looks good.
  • donald3 Feb 09, 2008
    the red light goes to the stting but it wont heat up the green light wont go pass to ntch
  • Anonymous Mar 20, 2008
    Shark gl490 light up but just won't heat up
  • nannielee Feb 25, 2009
    My unit will not heat up/ the lights work/ only 13 months old
    Problem Solver:
  • 14 Answers
What sounds like is the fuse that governs the heating of the unit is either burned or not functioning. You can get a manual on how to fix that directly from feiyue yamata's site here. http://www.feiyueusa.com/Manual/FP202ELFuseChange.pdf
The problem is that if you have a psp990, it is not their item, it is a rebranded yamata so they dont have specific instructions for it. After you changed that fuse, i am almost positive you will be able to use your press again.
Posted on Jul 08, 2008
I also have a Yamata PSP-990A with the following symptoms. Will not heat. Red power lamp illuminated-Yellow lamp illuminates when steam buttons are pressed-Green lamp off.
I dissembled the device and drew an electrical diagram and electronic schematic (circuit board).
The problem was a defective 12V zener diode (D3) which supplies voltage to the 555 chip (IC1). The output of this chip (pin 3) is connected to the base of an NPN Si transistor (BG1) to energize the 24V relay supplying power to the heating elements.
Since D3 is in series with zener diode D4, I replaced both parts. The diodes are 1N4742A and can be purchased from Radio Shack in a package at little expense.
The device is now fully functional. Hope this helps.
Posted on Mar 29, 2010
  • 625 Answers
You will need to open up an access plate to gain entry to where the wiring is. the indicator lamps are wired to the same terminals that the element connections are. check for a burnt off connector or a burnt wire at a connector where it goes into the connector. these are normally push on spade connectors that are crimped to the wire. if one of yours are burned off, obtain another terminal and get a crimp on tool and do the repair.
Posted on Jan 05, 2008
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
My yamata fp202L
Most likely it is the fuse that regulates the heating element on your press that has burned out.
All you have to do is open the top, remove the heating plate. The fuse will be on the left, button shaped.
Replace the fuse and put everything back together and the unit should work.
You can buy a fuse from the company you bought your press at or contact the manufacturer.
Sep 10, 2008 | Yamata FP202L Cordless Iron with Auto...
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
Yamata Steam iron 8800
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
May 11, 2008 | Yamata Gravity Professional GSI-8800 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Yamata PSP-990A Iron Logo
570 people viewed this question
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
