Question about GE WBSR3140DW Top Load Washer
How do you open up a ge wwwse3160aoww washer. the wash agitates fine but makes a lot of noise when it try to go to the spin cycle. it makes a bagging noise and spins slowly
  • 5 more comments
  • vgyogi Jan 08, 2008
    Thanks for getting me inside the unit but now I have the problem of trying to figure out what is making all the banging noise when if tries to go into the spin cycle. I looked and could not find anything loose (motor, trans)
    my unit is self balancing with some springs inside of some plastic cylinders. I by-passed the lid switch because I read that the switch could have been a problem, but that is not it either.The springs move when forced to move and I can push the drum down. it really sounds like metal banging or as if the transmission is hitting against the motor, but it is not.
    I checked the nut under the agitator an it was tight and rusted. I took it off and now I have to get a new one. So what's next?
    I figured something like that would be next. the noise that it is making sounds like metal to metal and I think something came apart in the transmission. is the brake inside the thrans or is it outside the unit?
  • vgyogi Jan 09, 2008
    I guess I will have to flip the washer over to remove everything. Is the brake inside of the transmission?
    If it is the brake inside the transmission that cost about $180.00 , it is almost coming out cheaper to buy another unit and sell the parts form this washer since I just need a good washer to clean the clothes. How would the brake be the cause of the banging noise?
    Thanks for all your assistance.
I guess i will be beating a dead horse for a few weeks, but, thanks for the info, vgyogi
Posted on Apr 28, 2008
  • 283 Answers
Slip a putty knife or other thin object between the top and front panels a couple inches from each side. You should see the clip release from the top panel. Pull the front panel down from the top
Posted on Jan 05, 2008
  • 3 more comments
  • GORDON'S APPLIANCE SERVICE
    Is it off balance? Is the basket loose?
    Below the agitator is a spanner nut that mounts the basket.You need to check that it is tight.
    If everything above seems tight it's time to pull the transmission and check the brake
    It's bolted to the frame underneath the trans. You'll have to pull the outer tub too. Not a job for the squeamish
    I agree. You're beating a dead horse
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
Ge washer wont agitate and makes a humming noise when in agitate cycle
That means the motor has shorted out if it is not spinning. The brushes inside the motor may have overheated and stuck. You can try tapping on motor inside wash machine to see if it will free up.
Jun 17, 2009 | GE WDSR2080D Top Load Washer
WHDRR418G1WW WASHER WON'T AGITATE OR SPIN, NOT MAKING NOISES. FILLS AND DRAINS FINE.
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
145 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
