Question about Mag Innovision LT576s 15" Flat Panel LCD Monitor
I have a Mag Innovision Flat Screen Monitor
The cable from the monitor to the computer is a 15 pin male connector to the Tower female connector.
The pins on my male connector for the monitor 2 are bent. I can get it to work, but then the pins get loose from being bent.
Can the connector be fixed by splicing another connector or manufacturer repair, or Do I have to buy a new monitor?
  • serenaty Jan 06, 2008
    I straightened the two pins, but they have been bent so much they will not stay straight. One even seems to have broken off.
    I thought maybe a new 15 pin connector could be spliced on the cable. The old connector I'm afraid is too damaged.
  • Anonymous Apr 03, 2008
    i have a flat screen tv trying to hook it up
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Jul 16, 2011 | Computers & Internet
What type of coaxial power connector is on the circult board to the Mag Innovision model LT 565 LCD monitor? I need to find a replacement part.
Most monitors use barrel type connector with 5.5mm outside diameter and either 2.1 or 2.5mm inside diameter. You can get both of them at Radio Shack. You do not want to use the 2.5mm if the center pin is 2.1mm it will not make good contact.
Jun 15, 2010 | Mag Innovision InnoVision LT 565 15" Flat...
here you go
Aug 07, 2009 | Mag Innovision InnoVision LT 765S 17" Flat...
Monitor only power's on NO sound and No Picture
check your cable to speaker of your monitor and to the audio output of your pc.
May 20, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
Need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI –
Nvidia -
Matrox –
Pinnacle –
Trident -
Diamond Multimedia –
Cirrus Logic -
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
May 26, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Innovision LT576s 15" Flat Panel LCD Monitor Logo
119 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
