LG Front Load Washer
About 2 out of ten loads creats a big puddle of water on the floor. I have examined drain lines. There is no leak or overflow from the tube. Also all pluming connections are tight . I cant seem to find where the water is coming from to begin reparing.
  • 4 more comments
  • baylie Jan 08, 2008
    It seems to me it is coming from the air vent for safety. I have notice that water spots are under it. I have called for it to be checked but I am still waiting to schedule.
  • outdoor guy Jan 29, 2008
    I noticed water on the floor. The water comes from what appears to be a vent at the top of the washer. The owner's manual provides no help.
  • simcompany Feb 08, 2008
    I too have a leak fom my LG WM2688 front loader. My water leak only happens when I use the HEAVY load cycle (towles). Serviceman came out and found no obvious prolem.
  • jill renee Mar 20, 2008
    I am finding small puddles of water under the machine after loads of towels and also jeans. Other times, there are small dried water spots...so obviously it has done it before and at other times. There were 2 occasions that I had very LARGE amounts of water when washing rugs and bathmats. What's the deal...the reason I bought this was to be able to wash LARGE loads!! Mine is still under warranty, just under 1 year of using it...what do you suggest. I always disliked my topload "old" maytag because of the off-balance issues...but at least that machine knew enough to turn off. Never had water on my floor before this. Please advise! I have a finished basement below my laundry room and really don't want a disaster!
  • gators07 May 27, 2008
    i actually caw the leak, at the 6 minute on the timer , ie rinse cycle. saw suds /water coming out the airvent under the water hookup on the back.
    this is a very intermittent problem with our lg 1814.
    will try less HE soap, will try a pressure reducer on the line.
    5 others described the same problem with their wm1814cw. water on the floor after a wash cycle. and it appears to be intermittent.
    i lucked up, saw low suds/water coming out of the air-vent ? right under the in-hoses while it was spinning out the rinse water with 6 minutes left on the timer, but it had to start a minute or more sooner as some had already puddled on the floor. we use HE soap in the suggested amount.
    is it possible while in spin cycle some air is sucked in somewhere causing an excess that goes out the airvent picking up water/suds ?
I've had trouble with my LG WM016CW front load washer leaking from the start. After many service calls, a Sears tech finally figured out that the water was running out the air vent on the back of the washer(leaks out even when no soap is added, so it's not a soap issue). The Sears tech called LG and it turns out that there should be mushroom valve(not on the original parts list) installed between the tub and air vent hose to prevent water from leaking through the air vent. That seems logical, so why wasn't the valve installed to begin with? LG is obviously aware of the problem, so why haven't they had the courtesy to inform their authorized techs? No, instead they wait for some poor tech to call them, then give out a part number that has proven to be dfficult or maybe even impossible to get(been 2 weeks and still no part). I believe LG is trying to hide the fact that the valve was left out of the original washer design and they do not want to go to the expense of correcting their mistake. Wish I could just return the washer, who wants one that leaks?
Posted on Apr 12, 2010
Occassional leaking of wash machine
The water may be a result of the drain not being able to handle the flow. This can be a result of either the drain hose not being in far enough, a blockage in the drain, or even a slow draining main line in the house. (The above applies if the puddle is from the drain area.)
Mar 31, 2014 | Magic Chef CAV2000 Top Load Washer
Tip
Our commode isn't leaking, yet it refills many times a day
If your commode is refilling over and over, you may have a Ghost Flushing problem. Even though there's no water on the bathroom floor, you likely still have a slow leak somewhere in the tank. To locate and identify the source of the leak fill the tank and shut off the water to the commode. Remove the tank lid and draw a pencil line along the top edge of the water line. Leave the water turned off and go back several times and redraw the pencil line at the water line. When the water stops draining see where the water level is. If the water has stopped just below the overflow tube, you likely have a siphoning problem. If the water drains to the bottom of the tank you likely have a flapper problem.<br />To correct the siphoning problem reset the the depth of the fill tube in the overflow tube. Fill the tank up, shut the water off, and recheck after some time. Repeat these steps until the water stops draining.<br />To correct the flapper problem gently lift the flapper and clean the bottom of the flapper and the flapper seat. Refill the tank, shut the water off, and recheck later. If water still leaks replace the flapper.
on Dec 28, 2010 | Plumbing
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
After every wash, there is a puddle of water underneath the washer, and it does not appear to be any of the hot, cold, or return hoses.
Check your drain. It might be slow and overflowing. Fill the washer and unplug it overnight and see if you get any water on the floor. Take the back off and do a load . Look for leaks. I have a manual and repair photos HERE
Dec 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Maytag side by side is leaking water from the freezer sid
We also had the exact same problem with our Maytag side by side. We kept getting a small puddle down on the floor under the freezer side of the unit. There was also a giant ice block puddle that had formed on the inside bottom of the freezer compartment. We solved the problem in about an hour. First, we pulled the unit out from the wall and checked behind and underneath the unit with a flashlight. The little drip pan that collects the water was completely dry. That told us that there was a plug somewhere in the drain line. We removed all of the food and shelves inside the freezer so we could access the inside, back panel. My husband unscrewed the two bolts and removed both panels. We found the problem. The drain pan had frozen and all of the water was overflowing inside the freezer compartment and ultimately out onto our floor. There was also a giant snowball around all of the wiring. We used a heat gun and gently de-iced the snowball and the ice in the drain pan. The manual also says you can use a hairdryer for this. Then, my husband used his air compressor and gently blew into the hole to clear out the blockage. We checked behind the unit again and saw that the clog had released and water was flowing into the drip pan. Problem solved. It is important to get the clog out of the drain line so that the problem doesn't occur again. We put everything back together and everything seems fine now. I am also going to check the defrost timer to make sure it is timing properly every 28 minutes or so. You need your manual for this to determine steps to check the timer. It is important for the timer to be set correctly so that the unit goes into defrost mode every 28 minutes. This will also help keep the water flowing and draining w/out having time to completely freeze up. The original root cause of our problem is we had a faulty ice-maker. It had overflowed about 3 months ago. The heavy surge of water, and the small plug in the line is what started this. Another problem we have had with this unit is the plastic tubing in the back. We had one of the lines turn yellow and crack. So every few months we pull the unit out from the wall, vacuum underneath and check the plastic tubing for leaks and breakage.
Jul 14, 2008 | Maytag MSD2456G Side by Side Refrigerator
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
Washing Machines Logo
1,610 people viewed this question
Top Washing Machines Experts
