my washing machine is not draining and I have already cleaned the hose and checked the drain. I suspect a clog in the drain inside of the machine. What can I do?
Make sure that your belt is not broken and is on the pump correctly then I would recommend that you put a hose into the drum, **** on it to create a flow and send the water to outside of your house or to a drain first.
Take your hose loose from the pump on both sides of the pump, but be ready for water to run everywhere.
Look in your pump to see if there is a clog, and also blow out both hoses, that should solve your problem
Good luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 7.0 cu. ft. HE4
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power...
(More)
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power going to the washer but it is just dead. Is there a fuse in the washer that can be changed or something I can look at.
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what...
(More)
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what should i do?
the dryer is beeping and the lights are going all over the place and the dryer is not drying the...
(More)
the dryer is beeping and the lights are going all over the place and the dryer is not drying the clothes. I f we unplug the dryer, and plug it back in it will beep again. It did run for a short time, but starting beeping again. The vent is cleaned after each load.
