the PIN that is being asked by you is the securtiy 4 digit no that you might have set for your sim card. The default PIN is 1234 or as set by your network provider. If you do not know your PIN then you can call your customer care unit of your network provider and ask them for it. If you have forgoten it, then also you have to call them and ask them to reset it.
Hope you this will resolve your problem.
Do reply back if you need more help.
Was this helpful?
Yes
No
Popular Solutions for Motorola i870 Cellular Phone
its displayin a message flash trap fs5v02.02 hab prd i28f256l18-romd cp blank service req'd unable...
(More)
its displayin a message flash trap fs5v02.02 hab prd i28f256l18-romd cp blank service req'd unable to flash
I little kid was playing with my motorola I870 and put a security code on it I don't know it how can...
(More)
I little kid was playing with my motorola I870 and put a security code on it I don't know it how can i bypass this to access my phone
when i turn the phone on it goes to the white screen that says i870 and then it goes black. It says...
(More)
when i turn the phone on it goes to the white screen that says i870 and then it goes black. It says i870 on the outer screen when i close the phone but it will not go any further than that. Before this started happening I was checking a text message and instead of it saying the names of the people it was just the numbers and it went down the middle of the screen instead of the side where they usually are. I took the battery out but nothing has changes. Is there a reset button or anything i can do from home because i'm in the middle of a hurricane right now
the motorola i870 works everting but can make calls they say no service the simm work good in others...
(More)
the motorola i870 works everting but can make calls they say no service the simm work good in others nextel phones
