Question about iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Is there any way to transfer voice recordings, line-in recordings, etc, from the iRiver x20 to the PC?
  • Anonymous Feb 12, 2008
    jio
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Posted on Feb 11, 2008
How to install iriver player T30 without cd
I assume you mean device drivers for when you connect to your PC or laptop. The following links should help you out ??
For latest firmware update (installs drivers and update but will wipe your device)
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
For iRiver support for the media player, go here
http://www.iriver.com/support/download_list.asp
Apr 09, 2016 | iRiver T30 512MB MP3 Player Voice...
Same happened with me, after mac connection
ok, plug it into the pc and run iriver plus 3, if you dont have it, you can download it from the iriver website.
then you connect the iriver.
then open tools>Portable Device>Disk Initialization..
this should format your iriver and give it default settings.
hope this helps you!
Jun 18, 2009 | iRiver X20 MP3 Player
Iriver X20 won't read on Iriver plus 3
this is a major problem i found with iriver plus 3. it tends to stall quite regularly. i suggest using wmp11 its just as effective. it cannot convert files but it syncs up quite nicely
Hope that helps!
Nov 08, 2008 | iRiver X20 MP3 Player
External memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Nov 02, 2008 | iRiver X20 MP3 Player
Deleteing voice recording
If you can connect it to a PC with XP on it, and have an iRiver Music Manager; once your device is recognized, you will be able to manually manage files on your iRiver, including deleting any voice recordings on it.
Oct 30, 2008 | iRiver iFP-895 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
Folders inside my IRIVER X20 no longer recognised!! HELP PLEASE!!!
Try making a new folder, under the same name as the ones lost, or missing. Since the X20 is flash memory based, you may have had some of your data go randomly corrupt. You MAY have to start things over. Sorry! Good Luck!
Apr 10, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Jan 05, 2008 | iRiver X20 MP3 Player
How do I delete voice recordings from my x20?
plug into pc and delete files via pc
that worked for me
Oct 25, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
66 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
