Question about Maytag PER5510 Performa Electric Kitchen Range
Maytag Performa Electric Range (PER5510) oven will not heat up
Broil works fine. Bottom heating element does not turn on in Bake and Clean modes
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 56 Answers
SOURCE: oven does not get hot enough to bake
Probably a failure to get 240 volts to those elements.
If burners work, then it's probably an oven CONTROL(S)l failure. Test them if you know how. Very difficult to find parts for a stove that old.
Posted on Sep 19, 2009
Testimonial: "very helpful as all 4 burners work but oven does not get hot enough to bake. As suggested I will search for new oven temp control switch. Thank you "
  • 197 Answers
SOURCE: My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Posted on Sep 21, 2009
SOURCE: Kenmore electric range 790. Both the broil and
I have the same problem... I checked both elements and they are fine. I was wondering if it was the ERC. Have you fixed yours yet? Please let me know.
Posted on Dec 06, 2009
  • 619 Answers
SOURCE: Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Posted on Feb 03, 2010
0 characters
1 Points
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
Preheats very slowly. Also, steam cleaning option seems to not be effective due to low heat. Is there more than one lower oven heating element?
For the oven their is 2 elements 1 for bake and 1 for broil,are each glowing red hot on the respictive settings of bake and broil? their is no trird hidden element. Plus i know manufactures come out with new features all the time,i attend factory trainging sessions a couple times a year but i am confused as to what the "STEAM CLEAN OPTION" IS??
THE SELF CLEAN cycle utilizes both elements to clean the oven adding steam is a new one on me
Aug 21, 2011 | Maytag MER7775W Electric Range
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Maytag PER5510 Performa Electric Kitchen Range Logo
524 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
