Question about Nokia 1600 Cellular Phone
1600 ringer problem
  • sharangopali May 17, 2009
    nokia 1600 ringer problem
How to unlock nokia 1600 and security code
Posted on Jan 07, 2008
I HAVE NOKIA 1600 HE GIVE ME PROBLOME THATS RINGER NO WORKING PLZ HELP ME
Posted on Jun 20, 2008
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
My mobile is nokia 1600, speaker is not working call voice is not licening
Then it means the speaker and earpiece of the phone is bad, this is mostly caused by water damage or the phone hitting a hard object. You need to replace the earpiece of the phone to be able to use it effectively, but before you do that, you can use an external earpiece that you will connect to the earpiece connection port on the phone to receive calls and make calls before you replace the speaker of the phone.
Hope this information helped.
Jan 10, 2011 | Nokia 1600 Cellular Phone
Hi anna i have a problem it is ringer is not working
Hi there
Go to menu,phone settings,ringer settings to check if your ringer is on or off,if it is off switch it on
If your ringer still isnt working then you should have your ringer changed.An expert or anyone with experience should be able to do that.
Oct 02, 2010 | Nokia 1600 Cellular Phone
Nokia 1208 earpiece ok but ringer is not working
if you can changed the ringer speaker inside then do ti.. because it is just the problem on it..
Aug 20, 2010 | Nokia 1208 Cellular Phone
Nokia 1600 is dead i have flash 3times it was not repair i have also ume heat
yes it often founds flashing problems in 1600 Nokia so my suggestion is that you must contact to a Expert Machanic/Repairer for flashing instead of you own cause many time experience gave a lot. it may be problem of battery. rechek with insertion of new batter if it doesnt work then cell may b useless forever.thanks
Jun 06, 2010 | Nokia 1600 Cellular Phone
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Phone wont ring on incoming calls, silence on screen.
Have you checked your alert status? You can access your alert status under phone settings or under profile, see if the ringer alert is turned of or if the phone is on silent.
Having checked the above and your phone still not rings, then it seem your phone ringer is bad and needs to be changed.
The ringer also might not be contacting the phone board very well and maybe that's why its not ringing out. If you have a phone screw driver, I would advice that you loose the phone and check the ringer, but if you cannot do it your self then you might take it to a phone repairer shop for though checkup or as the case maybe.
I wish you the best.
Nov 22, 2009 | Nokia 1600 Cellular Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Nokia 1600 Cellular Phone Logo
485 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
