Question about Motorola Mobility H700 Wireless Headset
Connecting phone with h700 headset
My phone which is a Motorola ic902 wont connect with my h700 headset
  • sarahjb Jan 10, 2008
    i have followed the "5 step" instructions all over and my H700 will not connect with my phone it was paired last night this morning it wasn't even on my list to pair what do I do? When searching it doesn't give anything
  • Kris84 May 19, 2008
    It doesn't have a problem finding my headset or phone, the problem is connecting. It will "Pair Successfully" and then it will try to connect. the only problem is that it keeps saying "bluetooth handsfree devise disconnected." But it was never connected in the first place. AHHHH
    Problem Solver:
  • 9 Answers
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Posted on Jan 08, 2008
I had been trying to make it work but nothing would do it until i read this solution.... thank you very muchhhhh!!!
Posted on May 20, 2008
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
My motorola h700 won't turn purple to connect to my motorola i576
Make sure the battery is good in your H700.Make sure your Bluetooth is enabled on your i576. To do this, go to Contacts>More>Bluetooth>Setup>Power> then select On. Back up one level and select Link To Devices. If everything is correct, they will find each other.
Dec 20, 2009 | Motorola Mobility H700 Wireless Headset
Motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
H700 wont connect to lg rumor
after pair successful highlight the headset and hit connect
Jan 07, 2009 | Motorola Mobility H700 Wireless Headset
It wont connect to phones
Compatible with Bluetooth v.1.2 enabled phones from Motorola and other manufacturers. Backwards compatible with v1.1 devices.
Jan 03, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
Motorola H700
llkjmm,mm dg k g bj r y yhgfhbdc hjjdsdfn jrusahnfda jjjjjjjjjavd h hjayb yhhujaylo jl,.ikan aahuabv ab ayasgbas bdtgmsa,bs asgfsa uw base rastuiysb iubnwe mnwer 8rt
May 19, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
373 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
