Question about HP LaserJet 9000 Printer
Have been getting the following error 83.0180 EIO 3 Error on an HP LaserJet 9000. Don't have the manual so don't know what it is.
  • 14 Answers
This is a network card error. the EIO card in slot 3 is probably faulty. Try swapping the card into slot 1 or 2. If you get the same error then you will need to replace the card.
Posted on Nov 06, 2009
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
I don't know the meaning of 49.ff04 error code
A critical firmware error has occurred.
1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter.
Jul 01, 2011 | HP LaserJet M3035 MFP Printer
I have an HP 4000N printer that is showing an E10 error. Can you advise what the problem is? Thank you.
EIO Error: Has to due with the additional card or hard drive on the back of the printer. If it's a networked based printer try the following:
Power off machine and unplug power cord.
Remove the network card from the EIO slot
Remove the cover from the other EIO slot (either below or above) and insert the card into that slot.
Power machine back on, see if error comes back.
If error is still present:
- Remove the card turn machine back on and see if the displays comes to ready.
If machine does come to a ready state than I would recommend:
- Replace the Network Card
If after replacement of card and attempted both EIO slots. Then you will need to replace the formatter.
Hope this helps!
Mar 07, 2011 | HP LaserJet 4000n Printer
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
I have an HP 5500dtn Color Printer and I am receiving an 81.018 EIO Error, what is this?
From the HP Service Manual
DEFECTIVE NETWORK Card, OR Formatter Board
bullet_red.gifUnplug network Cable or Parallel Cable from the printer and then turn it off and then on, if error goes away then it was a bad communication from the network or the computer
This usually solves this error.
bullet_red.gifIf error persists while printer is disconnected from the network or computer, replace the EIO/Network Card and or the Formatter Board
Nov 24, 2009 | HP LaserJet 5500dtn Color Printer
81.0180 EIO 1 error code on a hp laserjet 5500 dn
The printer has encountered a problem with an EIO card device in slot 1. Power off, remove the device from the slot and power on. If it comes up ready then refit the card and try again. if it still fails with the error recommend replacing the EIO device in that slot
Oct 07, 2009 | HP LaserJet 5500DN Printer
82.0180 EIO 2 ERROR
82.0180 EIO 2 ERROR
hp lj 4300 printer error code printer higout
Dec 31, 2008 | HP LaserJet 4050 Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP LaserJet 9000 Printer Logo
2,174 people viewed this question
Clive
Clive
