How to reset malfunction code C0500 of a imagistic im2020 copier
  • 149 Answers
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Posted on Nov 07, 2009
SOURCE:
C0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 01, 2014 | Minolta Di3510f Bizhub Copier
Malfunction code c0500
In minolta copiers the C5xx codes refer to fuser unit malfunctions.Verify the fuser unit gears,the fuserheater lamp continuity and the thermofuses continuity.To reset the codes please the copier model and I tell you the reset method.
Mar 01, 2013 | Konica Minolta Office Equipment & Supplies
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Codigo de falla CO500 en imagistic modelo 2520
la fotocopiadora presenta una averia y me sale cod c0500... quiero saber como puedo solucionarlo
Jan 30, 2011 | Office Equipment & Supplies
Minolta Dialta Di200 malfunction
1-The C0500 code can be reset following the steps below: find a small
hole on the right side of the control panel. press it using a paper clip
2) When the dot appears on the LCD after reboot, press the number 3 key.
3) The mode will change to the initialization screen.
4) Choose the selection for trouble reset.
5) After reboot the code will be cleared.
good luck
Feb 10, 2010 | Konica Minolta DiALTA Di200 Copier
C0500 error code
Verify the continuiti of the thermofuse and the heater lamp,cleaning it reset the malfunction codes to open /close the front door or enter in the service code Stop-00-Stop-01,acces 3 after appaire the * in the left side in the touch pannel,reset to trouble icons,press exit and total reset button twice.
Dec 07, 2009 | Konica Minolta DiALTA Di200 Copier
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 03, 2009 | Office Equipment & Supplies
I'm getting a malfunction code C0500
C0500 is a heater failure, the fuser section failed to get to the desired temp in a given period of time.
Try resetting the code, there is a reset switch behind the access panel,at the contrast knob inside the machine.
Hope this helps.
ed
May 04, 2009 | Konica Minolta Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
1,390 people viewed this question
k24674
Marvin
Marvin
