Proscan ps35160 powers off
Hi, I have a PS35160 chassis CTC179DJ. It will work well for a while ,about an hour or more, but then it gets white horz lines all over the screen and the sound pops. It also powers down and comes back on by itself. I have checked the tuner box for cold joints they seem ok.
  • lost1one Jan 11, 2008
    Thank you for your info and diagnostic help on my TV problem. I was sad to hear that news but I think you may be correct. I just may set this one out for the trash, it's going to consume too much time and mony. Thanks
    Novelist:
    Champion:
  • 232 Answers
Hi, thank you for posting make and model number, I`m afraid it`s all bad news for your set, the flyback transformer is getting ready to fail and because of the age of the set it is no longer available from RCA, heres the part number " 227318 " you can try calling some of your local shops to see if they have one sitting on the shelf but I wouldn`t hold my breath, sorry to give you bad news, if you have any questions feel free to e-mail me back, BMW Rider
Posted on Jan 05, 2008
We have lost the power cord to plug into our Proscan TV model: PS52652 chassis: PTK169PDBS. where can we find a cord to purchase?
Check with techs that repair these sets or any tech. If they cant find the right power cord they can allways take the power cord from another name brand set and wire it in.
Aug 05, 2010 | Proscan PS52650 52" Rear Projection...
I bought a new 27 inch proscan in 1991. It was
This is probably a tv with the "ctc-169" chassis. The BEST modern chassis RCA built. I own 2 of them that I USE, one is a 32" CONSOLE, a lot like your 27" set the other is a projo. I would keep BOTH of them ANY day--over ANY of the cheap, unreliable, fragile flat--panel sets today!!
FIX your set!! If the picture was good--it still will be--these sets had GREAT tubes in them. Most likely--a power supply isue with a couple of caps in the power supply, perhaps the controller chip for the chopper transistor, nothing likely serious. Probably about 150 repair--or less.
Oct 10, 2009 | Proscan Televison & Video
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
Jun 14, 2008 | Televison & Video
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Power supply of tv
if voltage drops means there is a short circuit in your tv. 1 disconnecting 120v line if supply becomes ok then there is short ckt in horz.section &if it does not gives 120 volts then there is problem in power supply. please check as per instruction &let me know. good luck.
Sep 19, 2007 | Proscan PS36500 36" TV
Proscan not turning on
Actually, the set has the PTK188AC chassis. This is a very uncommon chassis. The most common reason for the set not starting in that chassis is a shorted high voltage splitter. That is the large black box inside the set that has 5 thick red wires in it. When the set is turned on, the computer senses the short in the high voltage circuits and immediately shuts the set back off. When the set is on, that box has dangerously high voltage in it so it should only be replaced by a qualified tech familiar with the high voltage splitters in RCA projection sets.
Aug 28, 2007 | Proscan PS60690 60" Rear Projection...
Service menu
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
Apr 19, 2007 | Proscan PS36123 TV
Proscan 50" rear projection TV model S50-700
the life expectancy of a tv is 6yrs depends on how you take care of your tv.it can go for a long time.
Apr 18, 2007 | Proscan PS50700 50" Rear Projection...
60inch rear proscan picture hour glass problem
Most likly this set has two or maybe trhee problems .. first one sounds like a main power filter is open or the main power supply is at fault. the second coulkd be related or the cause of the first problem and could be shorted convergence ICs. the third could be a bad flyback transformer and good luck if thats the problem.. if the sets 10 years + in age, i would think very seriously into investing much to get this one going again.
Sep 11, 2006 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
