Vacuums Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vacume just does not want to turn on. and its only two months old its a germ guardian GGU300
Robert Sawart
Level 2:
Scholar:
  • Expert 65 Answers
  • Posted on Nov 06, 2009
Robert Sawart
Expert
Level 2:
Scholar:
Answers
65
Questions
0
Helped
41159
Points
226
Please check that all items on the machine are installed correctly. Filters Dust Cup etc. If this does not resolve your problem that try this:
For Customer Support Please Call 1-866-603-5900
Visit our website at germguardian.com
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
1helpful
How do I open the canister of the Aerus Electrolux Lux Guardian? I need to replace the retractable cord mechanism. Aerus won't help me.
This will not be difficult to open, however, inside may scare you.
Remove your hepa filter cartridge (if you have one)
turn the machine over.
Undo the 6-8 screws there and pull the bottom off.
you should see everything there. If you are careful, just remove the old rewinder, and replace with the new one.
Good luck.
Mark
Vacum shuts down when suction starts
Try turning the knob on the top of the vac all the way to the right.
Bad bag sensor
yes it is very simple to take apart and replace. for screws on the bag door and then it is only 3 wires to pull off of old switch
2answers
Don't know where to turn on the vacuum of the electrolux guardian. Bought it used. Can you help?
Usually these types of vacuums havve a foot operated switch that is part of the body and kind of blends in with the body of the vacuum, they may also have a switch on the handle.
1helpful
2answers
Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
1helpful
Vacum
Sounds like on/off switch, but need to meter out to check.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
