Question about Maytag MMV5156AAS Microwave Oven
Intermittant heating microwave has intermittant heating if just use no's like 220 for time on control panel does not heat up but if use sensor controls it will most of the time heatup...no burn odor and stirrer fan blade still works..
  • bailey bob Jan 05, 2008
    Now I have retried several options to cook including power level & also sensor controls now it does not seem to be heating at all no matter what I try...
  • 3 Answers
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
Posted on May 01, 2008
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
2009 whirlpool microwave
If the delay in heating is exactly the same each time, you might have some sort of control panel problem. If it is approximately the same each time, you may have an intermittent magnetron that is failing to oscillate until the heater reaches a high enough temperature to emit an adequate number of electrons.
Aug 06, 2016 | Whirlpool Microwave Ovens
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave not heating
There are few things it could be, intermittent door switch, magnetron, and a inverter board, "7 years old or less" or possibly the keypad control board.
Apr 29, 2012 | Whirlpool Microwave Ovens
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Whirlpool microwave, intermittent blower activity, shuts down microwave
Not clear what to explain but would look at the front control switches, commond problem, to see just play with the door open and closing to see what happen's with the fan, it's probroly not making proper contact, the other problem I can thing of is bad thermal heat sensor, there should be two or three of them, you need to know the basic what they do to test them just jump them, and try the unit and see if the problem stop to see witch termal is deffective.
Hope this help
Bob The builder
Feb 07, 2008 | Microwave Ovens
Whirlpool microwave
First...what do you hear? Is there any activity at all? If not and the light doesn't work and there is no panel indication...the problem is the inbound circuit. If all appears to be working and the unit isn't heating, the first guess is the internal fuse or the over temperature sensor. With the plug out, remove the control panel and have a look inside. There is generally a fuse which controls most things. With a circuit tester, you may be able to locate and test the temp sensors. They are black, about the diameter of a dime and about 3/8 inch thick. Generally, they are fitted to the metal near the oven side. The sensor should show continuity. If not, replace it. Generally, only one blows at a time. There are other possibilities...start here. Remember: internal voltages up to lethal levels exist when the unit is set to operate.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
The most common causes are a bad door switch, a loose connection at the magnetron terminal, a bad magnetron, a bad high voltage diode, a bad connection on the control panel, or a bad relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Or call 877-477-7278 M-F 10am - 9pm Eastern time. If you're not interested in doing it yourself, you can find a local Amana / Maytag servicer here: http://www.maytag.com/support/service_parts.jsp
Aug 27, 2007 | Amana AMV1162 Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
101 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
