Question about Dell 810 All-In-One InkJet Printer
Dell 810 all in one printer
Hi, just wondering if you could help me, i have the Dell 810 all in one printer, i have installed a new ink cartridge but all i get is a message pop up that say's ink cartridge missing? how do i solve this problem i have tried uninstalling the printer then re-installing it, the communication between my computer and the printer are fine. What would you suggest?
  • 1 more comment
  • Anonymous Mar 03, 2008
    I have the very same problem
  • bren1234 Mar 14, 2008
    I have just installed a new cartradge, but i am still getting a low ink message. What do i do?
  • Wozzle May 12, 2008
    My printer is reading the same. Ink cartridge is missing, after turning off printer, unplugging the USB port, it still reads the same, and won't scan to make the allignment page..
    Genius:
  • 1,142 Answers
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
Oct 09, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
Turn on your printer.
Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
I get a cartridge missing message in a Dell 810 printer
I am having the exact same problem. Just got my cartridge refilled, and whenever I hit the print command, I keep getting the message "printer cartridge missing." It's obviously there! gaahhh, so annoying! I hate dell.
May 09, 2010 | Dell 810 All-In-One InkJet Printer
Printer is blinking. I installed a new ink
Sounds like your cartridge may be unseated or it is really incompatible. You do not state clearly that you have printed successfully with this cartridge before.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Won't print
I insert the new ink cartridge still it saying ing is low( its original)
Mar 12, 2008 | Dell All-in-One Printer 810 with 2-Year...
Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 giving Incompatible Ink Cartridge error message
Hi try these steps
STEP: Disconnect and Reconnect the Printer Power Supply
Top of Form 1
Bottom of Form 1
Unplug the power cord from the wall socket.
Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Clean the Contacts and Wick the Ink Cartridge
Ensure the printer is powered on.
Lift the scanner unit.
Open the cartridge latches and remove the cartridges from the carrier
Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
Replace the cartridges in the carrier and close the scanner unit.
STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
Check to make sure the right carrier contains a color ink cartridge.
Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
Replace each cartridge in the proper carrier.
Let me know the status.
Regards
Dell 810 All-In-One InkJet Printer Logo
225 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
