LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading SteamWasher , WM2688H
Problem for LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading...
I have a lgwm 2677hbm washer and got a code read
By jbuncik on Nov 06, 2009
i have a lgwm 2677hbm washer and got a code read out de .i looked it up and it said drain error,i cleaned the drain filter but it sounds very loud during the rinceand spin cycle and i dont know if this noise is the pump or what.i stopped the washer because the noise has never been before.i just started a small load and wanted to see if and when it would stop and display the read out.i started a delicate load which starts at 34 mins.when it got to the rinse and spin cycle the drum would not spin and gave the same read out at 19 mins.the read out is drain error.help!
Solution #1
posted on Nov 06, 2009
Not Rated)
MNTECH
Rank: Guru  LG Expert
Rating: 94%, 933 votes
It is not likely an object got past the filter before the pump, so I'd guess that the impeller has come loose from the pump motor shaft. Replace the pump motor. (washer will not spin if water is still in drum)
Was this helpful?
Yes
No
Popular Solutions for LG TROMM 4.0 cu.ft. Ultra
LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading SteamWasher...
2 Solutions
1 Solution
1 Solution
1 Solution
1 Solution
Questions and Unsolved Problems for LG TROMM 4.0 cu.ft. Ultra
Do you recommend LG TROMM 4.0 cu.ft. Ultra Capacity Front Loading SteamWasher , WM2688H?
Answer
Answer
my LG Tromm clothes dryer blinks when turned on and will not turn off. The repairman came and it... (More)
Answer
In the middle of a wash the machine stopped, displaying "DE" I can't open the door to... (More)
Answer
how do i replace the door seal on my intello LG washer the old one is torn and worn can you help... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
