Question about HP Photosmart R707 Digital Camera
Red light! my camera doesn't even turns on... and i see only red light near the eye piece... its okay when i use it, but when charge it... boom! only red light & doesn't even turns on! help please...
  • 1 more comment
  • Anonymous Jan 22, 2008
    I have the same red light problem!! but mine is red all the time as soon as i put the battery in theres that little red recording light..
  • Anonymous Feb 06, 2008
    Same problem with my camera i.e. my camera doesn't turns on... and i see only red light always near the eye piece as soon as i insert my battery in camera. I have tried to reset camera by pressing the reset swith near the door by inserting a paper pin for more than 8 seconds... But no improvement. Please suggest me possible solution.................
  • Anonymous Feb 07, 2008
    Hello all.
    My camera does not turn on. As soon as I insert the battery red light turns on. This is the same red light, which glows when we make video recording.
    If anyone knows solution please suggest me...
Same problem! anyone heard any solutions?? i can't get the red light off, and i can't get the camera to turn on. help!
Posted on Feb 27, 2008
Dstv remote doesnt work..
Take your cell phone and turn the camera on, then aim the remote at the cell phones camera while pressing different buttons.
The infra red light will become visible and be flickering at different intervals depending on what button is pressed.
That is the start to see if it is even "TRANSMITTING".
Any infra red device that transmits will do this on a web or cell phone camera regardless of what it is.
They can see what we cannot with out eye!
Start there first if all coding fails and you still have the red indicator light working.
I hope this helped solve step one!
Robert W!
Jan 25, 2015 | Televison & Video
I have a Canon SD 790 and have tried everything to get the red eye reduction function to work. Problem is, I don't have my manual and can't find it in the 227 page download! I have looked through the tools...
Red eye reduction doesn't work that well on cameras. You would be better off importing your photos into a program like Picasa and fixing the red eyes there. Picasa's red eye removal is one of the best out there and very simple to use.
What you could also try is diffusing the flash somewhat. Put a piece of tissue paper over your flash is one way to do it. Or try bouncing the light from the flash off the ceiling with a piece of card (I've even used a piece of torn paper plate to do this)
Aug 28, 2013 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Won't turn on
You can try to reset it. You can do this by taking out the batteries. You should then see a flat, kind of square piece of metal with a small black piece sticking up from it. Take a pencil or something similar, and push the black piece down wait a few minutes then try turning your flip back on.
Mar 15, 2010 | Pure Digital Flip Video Ultra Camcorder
Even with the red eye reduction function turned on I still get red eye----why
Red eye happens because the flash is close to the lens. Even with the red eye reduction function, you're still going to get some. You can either use off-camera flash, or correct it in software.
Dec 30, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
The camera suddenly won't charge. And, my computer says it recognize the USB connection. Help!
Same problem here. We used it approximately ten times and now it won't charge (red light stays on). Even after resetting the camera as suggested in the manual. What can i do to solve this? We did open the camera and noticed that the red wire is hanging lose. Is this normal? Or do you have to connect that red wire to the battery? Has someone a more technical manual?
Dec 22, 2009 | Uncle Milton Pet Eye View Camera
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Turn off Red-Eye reduction
Hi - You can download the manual from the link underlined in blue below:
FinePix F10
See page 37 to turn off red eye:
Aug 19, 2008 | Fuji FinePix F10 Digital Camera
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
HP Photosmart R707 Digital Camera Logo
172 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
