its not sucking up the water off the carpet , no suction , it's spraying , the scrubbing brushes are spinning , I can feel air blowing out of the side, I don't know if i usually feel that are not
Hello. Take out your recovery tank, remove the lid, and re-attach lid rolling it from the front to the back, there are two tabs on the tank that the lid has to be aligned with, you will hear it "click" when it is tight. I think this might be the trick! Let me Know if I helped. Thank you. Rene (The Vacuum Doctor) Don't forget to have your unit serviced once a year by a qualified tech!
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off...
(More)
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off an I pull the triggar it flows big time out of bottom. tank doesnt leak when off sitting with water in it
The hoover steam vac 5 brush agitator dispenses water and soap but does not show any return water to...
(More)
The hoover steam vac 5 brush agitator dispenses water and soap but does not show any return water to dirty water reservoir. The carpet seems damp but not soaked, still a bit troubling no waste water...what up ?
(More)
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam...
(More)
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
