I've got a Sceptre 19 in monitor with the typical "on for a sec and goes dark". I removed the 6 screws on the back of the case but obviously there is a further step thats alluding me...how to you crack the case??
You need to use a plastic scribe to run around the edge of the monitor seam. A plastic scribe is a tool that looks like a knife, but it is not really sharp. Pry into the seam on the monitor and gently but firmly work around the edge until it pops apart.
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any...
(More)
Monitor has no power (ie. no light). Has integrated pwr/aud/logic/inv board. No visible signs of any problems. Only have 1.6v at pwr switch, and 5v going to logic side of board. Board is model 490491200100R, can't find any information on this board.
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts...
(More)
hello. how did you reset the eprom on the lcd monitor? my monitor turns on for 2 seconds then shuts off. i took it apart and when i lift the glass and put i flashlight behind it i can see that the monitor works but the bulbs are not turning on. is there a way to apply separate power to the bulbs?
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned...
(More)
just like antdotwhat my monitor started doing the same thing as theirs on the same date. I turned on my computer and the on light flashed on and of constantly this time with a black screen. I turned the computer off and back on and the monitor started working properly. This morning I turned it on and same thing. I tried turning the computer off and this time it would not work. I tried this several times. I think the monitor is no good anymore.
