Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
USB flash disk not working
When I insert my flash disk , it is not working properly. The PC can not recognise it although it is saying ( it is working properly).
  • 1 more comment
  • rob03 Jan 05, 2008
    I have the same problem with the cruzer. when I open " MY COMPUTER", it shows the drive but when I double click, it says to insert disk...
  • MEDHAT Jan 06, 2008
    when i attach a (class 1 biilinoton) bluetooth USB, it works fantastic. also, when i attach a panasonic cable between USB port and the camera, it works very excellent.
    NO SOLUTION MAKES ANY USB DRIVE WORKS, CAN YOU HELP ME.
    P.S. I UNSTLLED THE NERO SOFTWRE, AND IT GAVE ME NOTHING.
    THANK YOU FOR YOUR EFFORTS
    DR. MEDHAT A SALAM
    OBSTERICIAN & GYNECOLOGIST
  • Evan Tremblay Jan 17, 2008
    I am having the same problem with my U3 Sandisk Flashdrive
I unplugged my flash disk in the middle of sending data into it. Now the pc recognises it but i cant open it,send data in the flash. what could be the solution for this kind of problem?
Posted on May 30, 2008
  • 4 Answers
Assuming you are using a Cruzer Micro Drive with U3 Smart, things can be a little confusing because the drive actually shows up as two independent devices. When you insert the drive, there should be two devices showing up in your list of drives. One of them is installed as a CD Rom Drive and the other one is a Removable Drive. If you double click on the CD Rom Drive instead of the Removable Drive and you don't have any U3 applications mapped to the CD Rom Drive, then you'll get an insert disk message because Windows thinks that the CD Rom Drive is empty. Just use the Removable Drive if you want to simply install and transfer files.
Posted on Jan 06, 2008
  • inchpebble Jan 06, 2008
    The above solution is directed towards rob03, not MEDHAT. For MEDHAT, see if you have Nero 7 installed on your PC. Apparently, it's a known problem with Cruzer drives not working with PCs that have Nero installed. If you do, return the drive, uninstall Nero 7 or use the drive on a PC without Nero 7 installed. Sandisk doesn't have a firmware fix for this issue yet. By the way, the drive works fine with Nero 6 around.
My PC (or friends) doesn't recognise my Databank usb2.0 64GB flash
Try the stick in another device and report back if you can read and write to the stick on that device.
Plug other USB things into that port to see if the port is good.
Although rare, some USB things allow themselves to be inserted backwards.
Oct 19, 2012 | Watches
Hi, I purchased a sandisk 4gb usb flash drive to use as a backup disk but when I tried to format it I got the message "windows unable to complete format". I see that this is a common problem and...
have you tried a different usb port. sometimes the usb port remembers and just says that didnt work last time so no it doesnt work. inserting it into another port will make the pc treat it as a new device. if that doesnt work try accessing it thru the command prompt usually it will be e drive
so go to the run bar in your start menu and type command then press enter the command window should open now just try to access it , type e:\ if it is there it will change to it then type format. just be careful that you are not in c:\ when you type format c:\ has windows and all your stuff on it. hope that helps.
Jan 11, 2011 | SanDisk Electronics - Others
How can i fix my kingston dt101 2gb flash drive
The OS format tool will not format flash driveswhat you need is this one
http://en.kioskea.net/download/start/download-127-hp-usb-disk-storage-format-tool
Although it was produced by HP it works on any,
Jul 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb kingston 2gb always say insert disk e:
try inserting your usb to another usb slot., if it doesn't work try restarting your pc/laptop, if it still doesn't work, most probably that your usb disk is already damaged...
Mar 31, 2010 | Kingston flash memory card - 256 MB -...
Removeable Disk Not Recognised. I have my USB labelled SONY USB 2.0 I GB. once I plug it on my computer never recognised. So am asking you to get better solutions, Regards, charles
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 12, 2009 | Sony Electronics - Others
Micro sd 2gb card, not read.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
I just got a new 8GB SanDisk Mobile Ultra microSDHC card for my phone. While it seems to work in the phone, this is not a whole lot of good, as it doesn't work in either PC I've got here (both running...
r u sure your pc is usb 2 not usb 1 coz some pc will not read usb 2 if it has usb 1 that is wot i found with my adaptor so check that out if not tri a diff usb slot and if it dont work then tri and udr a diff adaptor
Aug 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
319 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
