Projection Televisions
Problem for Sony Projection Televisions
Generic problem for all Sony Projection Televisions
It keeps flashing between flashing lig...
By topaz1975 on Nov 06, 2009
It keeps flashing lights on the front panel, know as A & B, I believe these are in relation to the two scart sockets at the back of the TV. Since this started happening it first put it self on standby a few times and no it simply wont go back to showing a picture but stays in standby mode or flashes. Otherwise it doesnt show any lights at all and appearances would make you think the TV is not swithed on. Please help.
Solution #1
posted on Nov 06, 2009
Somewhat Helpful)
ginko
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 5102 votes
Hi.
The TV stays in standby because protection circuit kicked in.
Protection kicks in when an internal fault had been detected.
In your case the SCART cable may have caused a short.
When on protection the TV will stay in standby, will not respond to buttons or remote, and will not start up.
All higher voltages from PSU get shut down by controller board, and only the +5V remains on.
To attempt resetting the TV, disconnect all video cables, disconnect the power cord, wait about one hour and plug it back.
If TV does not restart, then there may be an internal fault.
In that case leave TV unplugged for longer, just in case.
If still no luck, then call Sony to discuss a repair. The number is listed on your owner manual.
If instead TV will restart, do not use the faulty video cable again, this can damage your TV.
Regards
Was this helpful?
Yes
No
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
not being able to adjust or locate the vertical hold button the picture , it had to have the tv warm... (More)
Answer
how to change a jvc hd-z56rx5 TV lamp.
Answer
the picture on the tv is fine but the numbers of the stations are upside down as is all text
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
Sony
(21591) 042-9690
Sony
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
