Question about Samsung PS42P2S 42 in. Plasma Television
Erratic samsumg plasma display
My samsung plasma tv keeps having 8-10 cm grey vertical display on left side of screen. this problem is erratic, appearing and disappearing in its own.whts the problem?
Yeah the problem maybe that ur power supply is not correct u should drop it off at 10 aston drive bulwell we have the correct supply!!
Posted on Jan 05, 2008
Hello , my name mike I Have a samsumg 42 inch plasma model pn42A450p1d . Picture looks good other than left side has a 3 inch black section from top to bottom. Any help
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 20, 2016 | Samsung PN42A450 Plasma TV
Lines on left side of my Samsung plasma tv
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 04, 2016 | Samsung Televison & Video
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Grey spots black screen
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
Sep 29, 2013 | Samsung PS-42A450 42" MULTSYSTEM PLASMA TV...
Two vertical black lines on the screen of my ps50b430
Unless someone played with the TV and disconnected the plasma display from the address buffer boards that go under the screen the prospects aren't good.
All vertical lines in all plasma TVs I have seen are operated by chips embedded in the fabric of the display as well.
When they fail they'd either short or burn open.
In the first case they'd prevent the TV from coming up, in the second they'd typically manifest as either black or a random color vertical line like you have.
This is not repairable...sorry.
The odds of this being something else is fairly minimal in my opinion.
Please don't kill the messenger...
bobby @ coppelltvrepair . com
Aug 25, 2012 | Televison & Video
1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
Aug 19, 2012 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
Hi, my Samsung LE26r73bdx has developed three grey circles (2inch diameter) evenly spaced on left hand side of screen. These are spaced vertically along the left edge. These appear to be growing slowly. ...
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 18, 2017 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
My Samsung plasma TV display a vertical line right in the centre of the screen, anyone having the same problem and solved.?
This could just be a cable problem.
Remove the back cover and carefully unplug all the flat cable connections on the left hand side (8) check / clean connections and then plug them all back in again.
Jul 21, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung PS42P2S 42 in. Plasma Television Logo
Jerry Greenberg
Jerry Greenberg
