Question about Britax Marathon
Stuck in recline
It seems that the base is stuck in a recline position. When I try to move the seat to the upright position it does not lock in place. It seems to move as far as it needs to but it does not click and stay in that position. I have been trying this when it is not attached to the car at all. It is in the living room. We have not reached the 33 pound limit for recline, but will soon. Please help!
Thanks!
  • baja44 May 27, 2008
    Same problem solution did not work
I know this post is old but I figured somebody w/the same problem might come across this. I had the same problem with my Marathon today. I also own a Roundabout & had no problem changing the recline myself. When my husband came home he took a look & fixed it. All he did was put it in the upright postion , held it in place & turned the seat on it's side & pushed up on the base and it clicked! he pushed on one of the corners (but I don't know if that even matters)
Posted on Apr 19, 2009
Has anyone else been able to solve this issue? My Marathon won't latch in the upright position, but will in the recline position. When I pull the latch, it will move like it wasn't to latch but won't ever click. The plastic on the front is all the way up, so I don't think it's an issue of how far it travels - the latch just won't catch.
I tried using some WD40 and it didn't help.
Posted on Jan 16, 2010
  • stocktsi Feb 07, 2010
    I tried spraying with a silicon spray and it didn't seem to help. I took the bottom off and made sure to spray all moving parts in there, and everything seems to be moving freely.
    Anything else I can try?
    Thanks.
Call Britax. They replaced ours no problem.
Posted on Jul 17, 2008
    Master:
  • 619 Answers
The lock are not move to engage slat due the lock are stuck /need to spray w/ WD40 pull the release to penetrate oil to moving parts.
Posted on Jan 10, 2008
07 Ford Expedition passenger seat stuck in recline position . Has power to it when I try to put it in upright position it moves slightly but it seems to be stuck
If it's binding the circuit breaker will shut off the recline motor. You have to replace the entire back frame to replace the motor
Dec 02, 2017 | Ford Cars & Trucks
96 Grand Marquise . Front passenger seat is stuck fully reclined . I took the seat out . How do I manually adjust it to upright position .
Not sure if you can. Was the motor not operating? Shoot 12 volts to it through jumper wires, see if that helps.
Nov 16, 2016 | 1996 Mercury Grand Marquis
Bmw 3 series 1996 Upolsterer had seat back off & now wont lock in upright possision
The gears for the recliner has been misaligned/broken. Disassemble and look for broken parts. Refer to service manual to realign,
Jul 20, 2014 | 1996 BMW 3 Series
Pontiac g6 seat recline lever won't work anymore
remove seat(s) and check for obstruction in the mechanism path. You'll need a big Torx bit.
Mar 22, 2014 | 2007 Pontiac G6
1990 Park Ave drivers seat recliner motor
You must remove the motor, move the seat to the desired position and then reinstall the motor to lock the seat in the position.
Sep 10, 2012 | Cars & Trucks
My maxi cosi tobi seat wont recline
Yes it seems to be a design fault. Has happened twice on our Tobi seat.
To fix, lay the seat on its back.
Locate the 3 Torx head screws middle front and rear left and right. You'll need a Torx screwdriver or head of the correct size. http://en.wikipedia.org/wiki/Torx
Undo the screws, then pop the four catches at each corner with a flat-head screwdriver and remove the base.
Look at the recline mechanism, you'll see large bar at the rear (both sides) which is meant to be there. At the front, on one side or the other, you'll see a smaller bar which is part of the hinge for the recline handle. It's slipped sideways and into one of the recline mechanism slots.
Jiggle the recline handle and push the hinge bar back into the centre. It might help to use gravity - lay the seat on its side with the blocking bar uppermost. I can't see a way to prevent this slipping out again over time.
Snap the base back on and replace the Torx screws.
Jan 03, 2010 | Baby Gear
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Jul 22, 2008 | 2000 Ford Focus
Britax Marathon Logo
565 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
