You have to find out IF parts are available! Number One! I've torn down many flat screen tv's and monitors, usually damaging the plastic trim around the units first happens. You should probably look into a New TV.
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD panel are given. You can compare it to that of your TVs' and can make sure about the fault.
To know more about this, you have to download the repair manual to this TV. Its disassemble section will have all the details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
I'm assuming you have a high definition cable box connected to this television with an hdmi cable a motorola perhaps. If that is correct then with you motorola cable box power turned off press the menu button on it. Yes I just stated that you turn off your motorola cable box and then press the menu button on it. A hidden menu will pop up on your television screen. Yes the television should be turned on but the motorola box should be turned off when you press the menu button. I am sorry for reiterating that so many times but there have been numerous persons that have been more concerned about why this works in this way than just getting it to solve their problem. So you navigate down to the color space setting. You will be able to navigate left or right to choose a different setting under color space. You will see maybe RGB of YCbCr 4:4:4. Choose the one that your cable box is NOT set to currently and the green line should go away.
It can be, but beware that the price of a new screen is 2/3rds the price of the TV. It would be more logical and practical to purchase a new TV that would come with a new warranty. If the crack is in the inside of the TV screen and it is still under warranty, this is usually deemed as manufacturers defect and it would be repaired or exchanged by them.
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
