Acer e lock activated??????????????
Hi
Have had my computer for nearly two years and just recently have been getting this message
Optical Drive Device Locked
Acer e lock activated.
Feeling a bit of a failure as I don`t know how to get rid of this or sort it out and now my cd is not working ( access denied).
Still under guarantee but as I am sure this is just a case of finding the "right button" don`t want to trouble anyone.
Anybody got any bright ideas.
Help apreciated.
Thansk
margaret
  • 4 more comments
  • Abdulhameed Jun 13, 2008
    Hi everyone,
    I'm using acer aspire 4315, I used the acer e-lock management facility to lock my optical drive, but can't find it on "My Computer" after unlocking it.
    Pls anybody with solution should e-mail me on abdulhameedgiwa@gmail.com
    Thanks
  • Anonymous Jun 14, 2008
    usb
  • flem_mr Jun 14, 2008
    It is impossible that it could be me who forgot the password for e lock, because I never even typed in a password to begin with. It just made one itself, I guess. Is there any way to delete this program altogether?
  • nckmitchley Jul 02, 2008
    my pc is acer elocked but i did not put in a password. what can i do?
  • Richie2007 Nov 01, 2008
    Hi
    Sounds as though it has happened to a few other people.................CD/DVD is " lock activated " and unable to be used by a unrequested password ???? so HELP ME please anyone ....Many Thanks Richard
  • Anonymous Jan 22, 2009
    hi i have the same problem
    but a friend of mine unnistalled elock and empowering tools so how can i unlock my drives
  • 13,433 Answers
I have a working workaround solution to this problem - save yourself 100usd (what acer requests from the unlocking) and press the ask me button to send me the free(FREE POST TO FORUM) request, Il give you the workaround, will take less than 10 minutes to solve the problem, really not worth it to pay 100usd for something this silly.
Il possibly soon make a video tutorial on how its done but for now, send me a request and il tell you how to get rid of the problem.
Posted on Aug 16, 2008
None of the previous solutions worked for me. Here is what I did:
  1. Uninstalled all of the Acer programs using Add/Remove
  2. Went into regedit and exported the entire registry - this is a good idea whenever you touch the registry.
  3. Using the Find function, I searched for eLock and deleted every key in which there was a mention of eLock - be careful here - there are other combinations of these letters that are not Acer-related, so only delete keys with eLock that are Acer related.
  4. Rebooted
  5. Ran ccleaner or Registry Mechanic or other registry tool to clean out any remaining issues.
  6. Rebooted
  7. Created a new Restore Point.
  8. I can now access all removable drives, USB and CD/DVD
Cheers,
Allan
Posted on Oct 13, 2009
    Genius:
  • 1,601 Answers
Acer eLock Management limits access to external storage media.
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
�� Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
�� Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
NOTE: If you lose your password, there is no method to reset it except by reformatting your notebook or taking
your notebook to an Acer Customer Service Center. Be sure to remember or write down your password
Posted on Jan 05, 2008
  • Thomas Christopher
    Thomas Christopher Jan 05, 2008
    You can try this:
    You can reset the system to its default settings (all devices unlocked) by
    removing the password (leave the password fields blank when changing the
    password).
"Optical Drive Device Locked
Acer e lock activated."
when i insert a disk this msg appears .this has now caused me hs followinng;
i-all disks are not seen/sensored
ii- cds cant be played
iii no recrding but the task manger tell me the unit is workong properly advise.
adebua_ellysoncenety@yahoo.co.uk
Posted on Jun 25, 2009
I ran into this issue today with a client. I went into msconfig to fix it. I had disabled these services because they were not needed, but it caused all the removable drives to be locked. Here's the fix.
Go to Run and type Msconfig
Click on the Startup tab
Expand Command column so you can read all of it
Enable 3 services all have elocked somewhere in the command
Restart the computer.
Posted on Dec 30, 2009
  • twolff333 Dec 30, 2009
  • 21 Answers
ELock workaround...
1. Disable eLock services
2. Restart
3. Go To Disk Management
4. Assign Drive Letter...
5. Uninstall then Reinstall eLock if you want to use it.
Posted on Aug 18, 2009
Simple, Just uninstall Acer Elock management in programs.
Then re install and create a new password.
Dont be fooled by rouge traders!!!
It worked for me!!
Cheers
Posted on Oct 09, 2009
Hi my d drive is locked and it is asking for a passwprd. acer laptop.
Posted on Jul 12, 2009
Hello! I live in Norway an have a problem with my computer - it says that acer e-lock i activated and i cannot use my dvd/cd station. I am not very good in computer "thing" so you have to explain very...
The Acer Elock is used to protect your computer from any external device or access like flash drive, any external media device, optical disc DVD etc.
To make the DVD CD station active you need to go to acer elock interface and enter the password which you first entered on the computer while doing acer elock system.
http://acer-elock-management.software.informer.com/screenshot/54477/
This link can help you as it has a step by step method and screenshots also.
The only disadvantage of this Acer Elock system is if you forgot the password you need to go to Acer Custoer Center and get it fixed
Please check if the above things will help you and let me know.
Regards
Nov 26, 2009 | Computers & Internet
Acer desktop computer can not open cd-rom drive
try:-
1. select "my computer", right click on cd drive, and click on eject
2. switch off pc,then manually eject cd tray by inserting a strong paper clip in the small pin hole on the front of the cd drive,insert the clip for about 1.5 cm (half inch) in the pin hole and you will feel it press on a lever to open the tray slightly.
Apr 30, 2009 | Acer Power 1000 PC Desktop
I've researched this and it appears simply uninstalling the elock software may resolve it - if this is not a feature you require.
Since it is an Acer specific issue you may contact the manufacturer for assistance while it is under warranty.
Feb 01, 2009 | Acer Extensa 5420-5687 Notebook
you can on line and type acer e-lock deactivation
should tell you what keys to use to deavtivate and activate
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
Acer elock Optical Drive Device Locked
the_phobia,
My advice for you will be, go to Add/Remove Program, uninstall the acer elock, restart your windows, it should be running just fine. If the problem still persist. Please do come back here for more assistance.
Your rank for my solution is much appreciated!!! THanks
Acer eLock Management Password
its a litte tricky and bepends on the version installed,
if your intrested, I can attempt to fix it up with remote support?
this session will be open for 2 hours since posting
www.fastsupport.com
support key 196-852-726
if you have problems with the automatic installer, just use the manually download software link
some people have had problems with the automatic one.
Oct 06, 2008 | Acer TravelMate 2300 Notebook
Optical drive device locked
why have you made multiple useraccounts to ask this question?
Sep 06, 2008 | Computers & Internet
Acer optical drive device locked
without knowing which version of the program you got I can suggest for you to:
press start
select run
or
hold down windowskey and press r
type in services.msc
find the elock service, right click properties, disable the service, and stop the service.
you may need to set a new drive letter for the optical drives
(right click my computer - manage - left side disk management - find drives without letters, right click assing or change drive letter)
if you can't uninstall the program? its asking for a password? Its extremely easy to reset the password but would need to know what version of the software your running.
Computers & Internet Logo
8,288 people viewed this question
Alun Cox
David Payne
David Payne
