My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free. In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Was this helpful?
Yes
No
Popular Solutions for Samsung RS265LABP Side by Side
The refrigerator side is not cooling properly. When you open the refrigerator do the fan or motor is...
(More)
The refrigerator side is not cooling properly. When you open the refrigerator do the fan or motor is making a "groaning/clicking" noise. The noise stops once the door is opened. It sounds almost like the fan or something is hitting an ice build up but not sure. The freezer works fine but the fridge will not go below 55 degrees.
The noise is coming from the fridge side of the unit, it's a lot louder than usual and when I open...
(More)
The noise is coming from the fridge side of the unit, it's a lot louder than usual and when I open the fridge door, you instantly hear the motor windind down....
Since I changed the water filter, the ice maker no longer makes ice. The water dispenser still...
(More)
Since I changed the water filter, the ice maker no longer makes ice. The water dispenser still works, but there's no ice.
