Question about ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard
Sound my sound isn't working
  • 619 Answers
If under guarantee call the problem to Asus on line / if not covered
You may buy sound card w/ Installation CD a sound driver .
Posted on Jan 05, 2008
Sound is working on the tv but the picture isn't
Is there a dvd or cd that came with it. I think you need to install the driver of the TV to your computer for them to work well.
Jul 26, 2013 | Televison & Video
I have no sound on my vizio tv
Make sure the mute button isn't on. Also sets give you the option to turn off your "on board" speakers. If applicable, make sure this option isn't turned on. Identify if this affects all inputs, and depending on your setup, check you source. Make sure it is in good working order and that your connections are correct. Outside of this, sounds like your set will need to be serviced.
Sep 09, 2012 | Vizio Televison & Video
I don't have sound on my computer yet i have installed sound drivers and they are working well?
check in your control panel and go to systems.
Then go to hardware and under that go to Device Manager
In there see if there are any exclamation marks in your sound hardware,
conflicts and such.
If there are none then go to Sound Controls in Audio Devices and make sure the audio isn't muted in the windows program
Use this to do an audio test of your speakers.
If that isn't working but it should be check your wires to see if there is a break or if it is plugged into the the green colored jack for external speakers.
Jul 31, 2012 | Creative Labs Sound Blaster Live! 5.1...
No hot water
sound like a problem with the pump, feel the pump when its should be runing to see if it is,there should be a nut with a slot at one end if this is turning then the pump is working if not it isn,t.if it isn,t check it out
Dec 21, 2011 | Washing Machines
2005 sedona won't start all of a sudden. Doesn't make a sound except for a tiny whirring sound like the feul injectors. Replaced starter...still won't start. checked all fuses...they are good....
you could just have dead cell in the battery which isn't getting enough amps to the starter,, have the battery LOAD checked,, that will tell you if the battery is actually good, just because it registers 12 volts isn't necessarily an indication that the required amps are present.
Sep 27, 2011 | 2005 Kia Sedona
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
No signal on mother board when i turn on the computer, no booting, no sound of step booting, but the fan work.
The motherboard lights should turn on. First step make sure the hard drive isn't bad, see if you can hear it trying to run. If that isn't the issue you will probably have to replace the motherboard.
Apr 08, 2011 | Mercury P4VM800M7 Motherboard
ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
