Question about Samsung LN-T1953H 19 in. LCD HDTV
LCD TV I would like to remove the back cover of my Samsung LCD TV. I have removed two visable screws. Is there a trick beyong that?
    Problem Solver:
  • 11 Answers
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Posted on Mar 09, 2010
How can i remove the back cover of my UN40F6300AF
with screwdriver take out every screw and remove back cover i did not have picture or video to show, sorry
Mar 14, 2017 | Samsung UN40F6300AFXZA - UN40F6300AF 40...
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
How to remove the back panel from a samsung lcd tv ln-t1953h
One of two general answers----look to see if screws all around the back of the set--if so set must be safely laid face down(no pressure on screens) and base removed first then the screws. Also some sets in addition have tabs around the back cover that snap the back on---use a thin metal putty knife and probe to snap them loose----left to right etc.
Oct 29, 2012 | Samsung LN-T1953H 19 in. LCD HDTV
My samsung tv's backlight doesn't work can i fix it
yes; you can replace the back light of your lcd, when you remove the back cover of your lcd you should remember all the parts that you will try to remove specially the screw, then you will see a rectangular pcb in the other side it has a small transformer this pcb is the inverter of the backlight of your tv try to follow the wires that is connected to this inverter and you will see the back light of your lcd, try to check the tube both end if there is black color then it indicates that the cathode tube is already damage.
Jul 17, 2011 | Samsung LA40R81BDX 40 in. LCD TV
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
How do you remove the bottom mount from an lcd samsung so that it can be wall mounted?
Page 85 of the manual has it, and can be downloaded here.
Here's what it says to do:
1. Place the TV face down on a soft cloth or cushion on a table.
2. Remove four screws from the back of the TV.
3. Separate the stand from the TV.
4. Cover the bottom hole with a cap.
There is a picture in the manual that indicates that the four mentioned screws are the four on the bottom back of the television.
Feb 01, 2010 | Samsung LNT5265F 52 in. LCD HDTV
I removed all screws from the back of my lcd tv to replace minor part and i still cannot pry open the back cover. Seems to be stuck inside the middle.
U sure all the screws are remove.I have taken out many tvs and monitors,all way open.Recheck the middle might have some screws might miss or some covering might cover it.
Jan 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
How do I remove the back panel from a samsung LN-408D? I have removed all of the screws, but the panel doesn't seem to come off.
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
Jun 29, 2009 | Samsung LN-R408D 40 in. LCD HDTV
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LN-T1953H 19 in. LCD HDTV Logo
356 people viewed this question
Jerry Greenberg
Jerry Greenberg
